What the heck is up with my headlights???
Old Jan 17, 2009 | 10:21 PM
Antipd32v's Avatar
I am having trouble with my high beams (brights) when my head lights are on and I pull the brights on, the blue light comes on but my brights do NOT turn on. If the headlights are turned off, and I pull the brights on the blue light comes on and the head lights just turn on. If I have my head lights and my fog lights on and I pull the brights on the fogs turn off and the headlights stay on but no brights turn on. Can anyone help me? I don't think the bulbs are bad, its hard to imagine that both brights would go out at the same time....
Old Jan 17, 2009 | 11:22 PM
Redpit10's Avatar
Well the fogs and highs are a duel filament bulbs, so my guess would be you had an electrical surge while your brights were on and they burned out both high beam filaments. Just a guess.
Old Jan 18, 2009 | 11:56 AM
Antipd32v's Avatar
^^^^^ Dam that would suck, from my understanding its a bitch to replace bulbs in the g35. Any one have a DIY ????
Old Jan 18, 2009 | 12:24 PM
Hi-TechG35's Avatar
^You have to remove the front bumper and take the headlights out. This can be done in about twenty minutes.
Old Jan 18, 2009 | 01:19 PM
Mustang5L5's Avatar
You just unscrew the fender liner in the front wheels and you can reach in there and take the bulbs out
Old Jan 18, 2009 | 06:56 PM
gtbigup01's Avatar
^^ what he said, you just have to partially remove the liner to replace the bulb. I have PIAA extreme whites for my highs/fog and have no clue how to remove my front bumper, that would be waaaay more work than is required.
Old Jan 18, 2009 | 07:57 PM
TurTLe*'s Avatar
the bulb work make the most sense but seeing as how there are 2 ways to activate high beams and only one works (manually lifting the switch) the switch can be the problem. Normally you only see 1 bulb go bad not 2 but anything can really happen.
But either way i would replace the bulb first as it is the easiest to do and cheapest for that matter.
Old Jan 19, 2009 | 12:33 PM
Antipd32v's Avatar
if the brights are burnt out, would the blue "warning light" come on when I turned them on?
Old Jan 19, 2009 | 12:58 PM
G SEDAN's Avatar
yes it will, your car doesnt know when the bulbs are burnt out...only when it activates the high beams.
Like others have mentioned.......change out your fog/high beam bulbs and you should be fine.
Old Jan 20, 2009 | 01:57 PM
Antipd32v's Avatar
ok thanks, i will probably get on it this weekend. I will shoot an update in a few days...
Old Jan 20, 2009 | 05:09 PM
Antipd32v's Avatar
Can any one give me the bulb part number, I am trying to order online and I am having difficulty with finding the correct bulb... Any help would be much appreciated thank you!!!
Old Jan 20, 2009 | 05:43 PM
G35Papa's Avatar
H4 is the bulb you need
Old Jan 20, 2009 | 05:56 PM
Antipd32v's Avatar
Thank you sir, any recommendations on a good place to order from online
Old Jan 20, 2009 | 06:00 PM
G35Papa's Avatar
You going with OEM or aftermarket?
Old Jan 20, 2009 | 07:32 PM
Antipd32v's Avatar
either way doesn't matter stock or aftermarket as long as i get my brights back and working. I called a dealership and they asked if I have HIDs or not... and I honestly don't know... does it matter?
