How important is the front spoiler?
Old Feb 9, 2009 | 06:50 PM
G35NC's Avatar
I wasn't sure where exactly to post this concern so if the mods need to move it, I apologize.
Concern/question: Yesterday I did a complete hand wash of my '05 sedan and noticed the front spoiler (not sure if this is the correct term), the black, plastic thing that stretches the width of the car under the bumper, was close to falling off. In fact, it was completely detached except for a few inches on each end. Seeing that is was not re-attachable, I removed it completely.
Is this front spoiler necessary? Has anyone had theirs removed and or replaced. I wonder how expensive that would be?? I prefer having one rather than not but just wonder if this will effect the cars performance at all (wind resistance, lift, etc).
Thanks for any advice / input.
Old Feb 9, 2009 | 06:56 PM
slow600's Avatar
I dont think that you have to have it bit im not for sure though.
Old Feb 9, 2009 | 06:57 PM
CandlestickPark's Avatar
ill Sedan
+1, I don't think its an issue not running one. I know Dexter (dahkyne) hasn't run one for a while, it was scraping and just fell off.
Old Feb 9, 2009 | 08:29 PM
LEON NYC's Avatar
It's not important as to keep the car functioning and all, aerodynamic wise, I dont know maybe you lost 2% control? I know mine is scraped up from the concrete barriers I tip sometimes when parking in lots...
Old Feb 9, 2009 | 09:38 PM
lexusk8's Avatar
I've been running mine without one for the last 5-6 months, and through a few days of wet/dirty conditions, I haven't run into any problems. It might get a little dirty under there but that's it. Makes oil changes a lot easier since there's no underbody cover piece to remove to access the oil drain plug and filter.
Old Feb 10, 2009 | 03:30 AM
evosmudge's Avatar
I think I like my G's side view more than the front because I continue to forget that it is missing on mine (purchased used). I only remember that I should have one when I see other Gs. Should I get one and how much are they?
Old Feb 10, 2009 | 06:34 AM
mcraerc's Avatar
Ditch it...
Lose it and pick up a Front Chin Spoiler from Grubbs or Everything G35. Mine fell off after I put the H&Rs on. With the car lower you will not miss the extra down force from a little piece of plastic.
Old Feb 10, 2009 | 07:34 AM
Texasscout's Avatar
Mine's gone and I only notice a difference above speeds of 100+mph. The front seems to get a little light. I'm looking for on of those garage door seals to try the "Home Depot" splitter mod.
Old Feb 10, 2009 | 08:03 AM
Infiniti Chica's Avatar
I'm not exactly sure, but I would imagine that the spoiler is a fully integrated part of the already sleek shape of car, which gives it dramatically improved aerodynamic properties. The spoiler is likely a factor on the coefficient of drag. The front spoiler pushes more of the airflow at the front over the surface of the body rather than allowing it underneath. It probably is designed to channel what airflow there is under the body rather than allow it to dissipate from the sides and through the engine bay-- which would cause more drag. I also wonder if it might have an effect on wind noise, stability at higher speeds and mpg.
Old Feb 10, 2009 | 12:28 PM
FenixL1P's Avatar
park farther away from the curb and/or bumpers next time.
Old Feb 11, 2009 | 12:19 AM
coolieman1220's Avatar
the front of mine started to hang low beacuse the bolts stopped catching or the washers broke through the plastic. i drilled extra holes and cable tied it up. holds well. figure the two times a year that piece comes off.
Old Feb 15, 2009 | 11:42 PM
IPGSEDAN's Avatar
My car was recently hit from the front and i noticed that they never put the part back. Were can i buy this. What is this part called excatly?? i heard it affects your performance and handling significantly.
jsimonk
Dec 22, 2023 03:49 PM
derres
Aug 28, 2015 03:27 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
Karnicle
Jul 23, 2015 05:08 AM
