tcu and ecu reprograms
Old Jun 21, 2004 | 03:14 PM
madabs's Avatar
im going to have my window fixed on weds cause it keeps making a poping noise after it is rolled up. I also want my ecu reprogrammed because it doesnt shift smoothly in mm. Can anyone give me the codes so i can tell them which ones to switch them to. I have the 03.5 and its auto. thanks in advance
Old Jun 21, 2004 | 08:46 PM
slowsocalg35's Avatar
Re: tcu and ecu reprograms
I just had them re-program the Transmission TCM software in my 2003.5 G35 AT Sedan to 31036-AL004. The old version was AL002.
Don't know of a dealer update to the ECU.
Old Jun 21, 2004 | 09:32 PM
JKRD101's Avatar
How much does it cost, can it be warrantied?
Old Jun 21, 2004 | 11:08 PM
They charged me $60 to reprogram it. I'm sure if you went in with the Technical Service Bulletin in hand and said you had the symptoms described in the bulletin they would do it for free.
Old Jun 22, 2004 | 08:18 AM
SixFive's Avatar
Can you please describe the 03.5 after the upgrade? I think my tranny is pretty good after a reset - is it worth doing it anyway?
2003.5 DP 5AT Sedan (E-thing but Nav)
14.2 @ 97.18
Z-Tube
K&N Drop In & Airbox Mod
10 Wire Hyper-Ground
Crawford Plenum (V4)
UR Crank Pulley
Polk EX-3500 Tweeters/Shock Sensor/H-Liner
Old Jun 22, 2004 | 10:28 AM
I think the people who notice the greatest improvement are those who shift their automatic transmissions. If you just put it in drive and roll around like I do, maybe the shifts are a little bit quicker, not a huge difference. But for $60 I wasn’t expecting a night and day difference. This isn’t like the TechnoSquare ECU upgrade where they try to maximize engine performance. This is just an improved version of the firmware controlling your transmission.
It may also be true that the reason I don’t notice a lot of difference is because there isn’t a great deal of difference between my original firmware version AL002 and the new one AL004. If you have the AL000 firmware version, you may notice more of a difference when upgrading to the AL004 firmware.
Old Jun 22, 2004 | 12:03 PM
Gordgee's Avatar
Administrator
I had version AL000, and did the upgrade to AL004. To tell the truth, I couldn't feel any difference.
<font color=blue>[i]GroundingGear™ Equipped </font color=blue>
Old Jun 22, 2004 | 12:16 PM
SixFive's Avatar
i know this has been hashed out but i cant figure out which version i have - how do you know?
14.2 @ 97.18
Z-Tube
UR Crank Pulley
Old Jun 22, 2004 | 05:06 PM
I think the only way to know is with an OBD scanner. I didn't know until I had it reprogrammed.
Old Jun 22, 2004 | 10:57 PM
Gordgee's Avatar
Administrator
I'm not sure a regular OBD Scanner will tell you either. It has to be the Consult II or similar.
Old Jun 23, 2004 | 03:46 AM
GurgenPB's Avatar
You can also look on teh TCM itself. Just take the p-side right kickplate off (after taking the door opening bottom liner off. Takes 60 seconds tops! The part # will be on the case
Gurgen
06g35
Feb 14, 2022 05:59 AM
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
MThawkins86
Oct 24, 2015 02:07 AM
G35VSHNG37
Sep 10, 2015 01:54 PM
Chadwick Arnold
Sep 9, 2015 02:59 PM
