Major electrical issue! need help asap
Old Mar 19, 2009 | 01:28 PM
STLTHSDN's Avatar
my tail lamps, plate lights and center console and hvac lights have all quit at teh same time! cheked fuses and found nothing! this is BAD and needs to be remedied asap! any ideas or fuses i havent seen etc?
Old Mar 19, 2009 | 07:03 PM
Philly_G35's Avatar
Did you check the fuses in front of the battery as well?
Old Mar 19, 2009 | 07:54 PM
6MTFTW's Avatar
There's a nice fault tree in the FSM. It looks like the only real thing that they share is the tail lamp relay. Download the FSM and follow that fault tree.
-Jerome
Old Mar 19, 2009 | 08:06 PM
ttrank's Avatar
Grocery getter
^+1
Has to be be a blown fuse. There is the fuse box in the kick panel and two in the battery area.
Old Mar 20, 2009 | 06:46 AM
Blue Dream's Avatar
I drove ttrank's car solo
Ignition switch
I have had the same problem before, and it turned out to be a bad ignition switch. Take your baby to a mechanic and have them check this. I paid about $250 out the door, but it wasn't on an Infinity. If you could do it yourself you'd obviously save $$$.
Hope this helps.
Last edited by Blue Dream; Mar 20, 2009 at 07:10 PM. Reason: I can't type for shizzle
Old May 21, 2009 | 07:46 PM
lightspeed1's Avatar
i am having tha same problem. I check the fuses in the driver side and i found another fuse box right in front of the battery and no fuse where blown..is there another fuse box somewhere else i dont know about that i can check?. By the way my license plate light is out so are my center console, and front door lights. I have an 04 G35X.
Old May 21, 2009 | 09:29 PM
strange my halos are out too..yet my headlights work fine and so do signal and brake lights..anybody know if may be my halos caused this problem?
Old May 22, 2009 | 10:38 AM
Pska's Avatar
is there any reason why cars don't have breakers instead of fuses?
Old May 22, 2009 | 12:41 PM
geew1z's Avatar
size, expense, corrosion.. the fact that most people dont blow their fuses in cars very often...
Tyler's03G
Aug 13, 2015 10:04 AM
Danielek
Aug 11, 2015 09:33 AM
wojowojo16
Jul 27, 2015 09:57 AM
