AWD light just came on- Need help troubleshooting
Old Feb 19, 2016 | 10:58 AM
Mustang5L5's Avatar
Originally Posted by saidsode
Yes mine just started doing that after I had my wheel bearings changed.
Wheel speed sensor either not reinstalled correctly, or was damaged during the bearing replacement.
Old May 17, 2019 | 10:28 PM
Maria Velez's Avatar
2004 black Infiniti
Need help
Originally Posted by da mayor
is the vdc and slip llight on as well?
My awd light is on with the slip and vdc who can tell me why and what to do
Old May 17, 2019 | 10:51 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
For a small fee of around $125 Nissan can do a diagnostic and tell you why.
Check your brake fluid to make sure it's not low, that can trigger those warnings.
Old May 18, 2019 | 11:29 AM
Said Sode's Avatar
Infiniti G35X
Maria, unhook the battery for a minute and hook it back up. It will reset the original settings. That's what I did and the lights went away. That was a year ago.
Old May 18, 2019 | 11:42 AM
G2B35AGN's Avatar
More specifically, remove the negative terminal cable.
Old May 18, 2019 | 01:08 PM
cleric670's Avatar
BANNED!!!
Even more specifically, your car is telling you something is wrong. Don't just erase the code, go down to a mechanic or parts house so they can hook it up to an OBD2 scanner and tell you what the problem is.
Alex Koss
Oct 29, 2021 12:53 PM
Cajuncowboy
Jun 21, 2021 09:47 AM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
Danielek
Sep 20, 2015 12:08 PM
Srinidhi
Aug 7, 2015 03:38 PM
