75,000 Maintenance
Old Mar 31, 2009 | 09:33 PM
sheerdog47's Avatar
75,000 Maintenance
Anybody have the following maintenance done and if so, any idea what you paid for it?
-Oil Filter Replacement
-In-cabin microfiilter replacement
-Brake Lines/Cables
-Brake Pads & Discs
-Automatic Transmission Fluid
-Exhaust
-Steering Gear & Linkage
Also, the backlight on my clock no longer works. What are the chances that it's a fuse?
Any insight is greatly appreciated!!!
Old Mar 31, 2009 | 09:34 PM
sheerdog47's Avatar
Sorry, it's a 2003 G35 with 77,xxx miles.
Old Apr 1, 2009 | 02:54 PM
ttrank's Avatar
Grocery getter
$3,100
LOL
No idea, I do all my own.
Old Apr 1, 2009 | 02:57 PM
jmcohen23's Avatar
call a couple different of dealerships (even some not in your area) to get an idea. I'm interested to find out, as I just had my 60k service ($600). So I can't imagine that the 75k would be anything above $1k.
Old Apr 1, 2009 | 04:30 PM
5150DS's Avatar
-Brake Lines/Cables
-Brake Pads & Discs
-Exhaust
Ask the dealer and then go to a trustworthy independent mechanic. The mechanic will almost certainly be cheaper.
Old Apr 2, 2009 | 11:47 AM
phrocker's Avatar
I have a sheet from my local dealership which lists the cost of scheduled maintenance intervals until 90k. It had a ton of work listed for 75k, and ended up being about 869. The listing was more than what the factory required, and undoubtedly included some superfluous checks.
Old Apr 2, 2009 | 12:41 PM
jimmyc13's Avatar
Highly recommend NOT going to the stealership for this service interval...complete waste of $ IMO. The first item is an oil change (go to who you usually go to or do it yourself), the 2nd one you can buy at local auto store & do it yourself in 1/2 hour...trust me, it's easy...you can get instructions on this forum how to do it. The remaining items are ALL inspections only and my guess is the stealership will want about $425 to do it! Take your car to a trustworthy local mechanic to inspect those items...will cost you fractions less if you're not able to perform yourself.
As for the backlight, I'd suspect the bulb is out.
Old Apr 2, 2009 | 02:23 PM
j 4 lD's Avatar
-Brake Lines/Cables
-Brake Pads & Discs
-Exhaust
If you're mechanically inclined, you can probably do all this yourself. You can save money, while enjoying you're car at the same time. There are a bunch of DIY (Do it yourself) videos all over the internet and on this forum. Some guy did a bunch of them here and they are really helpful: http://www.infinitihelp.com/diy/gsedan/index.htm .
You can for sure do the oil change (w/ filter), in cabin air filter, brake lines, pads, and rotors. The other stuff may be harder but it's worth a try.
Hawk pads: http://www.tirerack.com/brakes/brake...eet+brake+pads
In cabin filter: http://www.drivewire.com/npn/acc-cab.../infiniti-g35/
If you don't know what to do, it pays to research a little and find out how to service your car, so when it comes time to add mods, you can do it yourself as well.
Old Apr 2, 2009 | 05:34 PM
snotf's Avatar
the hawk pads are SO worth it, imho. when i bought the car it had oem(prob just cheap replacements) with huge dust issues. i've heard all over this forum that this is a common problem due to the weight of the x in particular. since switching to the hawks at 30k(about 12k in now), i've probably only cleaned my wheels once, maybe twice and they have had at most an eighth of the burnto on buildup.
Marlin84
Apr 1, 2020 12:52 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
c_elliott83
Sep 25, 2015 07:55 AM
DRG35R
Sep 16, 2015 05:33 AM
