Who says the Sedan doesn't get any Lovin?
Old Jun 25, 2009 | 05:36 PM
  #301
ProfanityPete's Avatar
Yeah, it doesn't appear that the XYZ pipe will fit, at least not with some extensions. I would be willing to do a test fit on an 04, depending on Tony, but I doubt it will fit.
Stinks, but I'd much rather have AWD than an aftermarket Y Pipe, especially in upstate NY.
Old Jun 25, 2009 | 08:08 PM
  #302
Bestswat's Avatar
Its not going to fit, dont even bother.
Old Jun 26, 2009 | 02:31 AM
  #303
IPGSEDAN's Avatar
Originally Posted by Hydrazine
WOW! I figured most Sedan drivers would "generally" prefer it on the quieter side.
OK.
Once I get the dual tip VQ out of production it won't take long at all to do the Shockwave.
AWWWWSOMMMEEE!
Price same as Z guys? Will it come with a dual tip option, I dont really care if it does, but i know this question will come up
Old Jun 26, 2009 | 07:23 AM
  #304
TurTLe*'s Avatar
Originally Posted by caly2121
From the pictures and discussions I have had with the mechanic thus far the VQ system is not fitting on my car as seen in the pictures from me earlier. This is quite possibly attributed to the y-pipes on 04's being different from 06's. If anyone knows anymore about the y-pipe differences and could add to this that would certainly help
Please expand on this...
04 and 06 y-pipes are diffrent. the 04.5 - 06 have a Y-pipe similiar to the HR pipe but not exactly. the Y on the 03-04 the top 2 peices are a lot shorter, the 04.5- 06 in the Y the top 2 peices are longer. your picture shows the top 2 meeting right after the transfer case. But in the end it shouldn't matter in terms of a catback since the total length is exactly the same.
Its very clear how the Y is hitting the t-case because of the where the top 2 peices meet is a lot closer then the stock Y.
But in terms of a exhaust system thats after the Y, it should be the same length, only thing that i can see that could be the reason is the position of the shafts due to the transfer case being where it is the drive shaft is in a diffrence place so it can hit or block the exhaust pipe.
the stillen system is the only system that is proven to work on the AWD models AFAIK.
Old Jun 26, 2009 | 08:24 AM
  #305
RicoG35x's Avatar
this is what I see with the different Y-pipes...
my ride had the old school short y-pipe.. the dealer installed the "HR lookalike" Y-pipe without the pucks.. I DID notice a deeper, louder sound, been very happy with it in combination with all the other intake/exhaust mods. Bums me out that the XYZ pipe has issues with the X
From the pics.. the X Y-pipe looks identical to the Z HR Y-pipe... the G37 Y-pipe DEFINITELY is different.. the pipes are even thinner, verified by another member on a previous post.
07 Z HR Y-pipe
G35x Y-pipe
08 G37 Y-pipe
The first two are exactly the same length.. DaveB and I are running the same cat-back OEM exhaust setup, with the exception of the version of Y-pipe... they were both direct bolt-on, no clearance issues or modifications required what so ever! only difference is one has the vibration pucks.. and the other doesn't.
Old Jun 26, 2009 | 08:35 AM
  #306
coup de grace's Avatar
FYI. I'm running the Motordyne XYZ pipe on my car. Have been for quite a few months now.
Old Jun 26, 2009 | 10:54 AM
  #307
caly2121's Avatar
In order to have done that 5" additions to either side of the Y to get around the transfer case. If you did not if you could provide pics that would help all others. The motordyne vq exhaust will fit with a spacer, I do not have exact measurements for the length however.
Old Jun 26, 2009 | 10:57 AM
  #308
Yeah, pics are needed, as I don't see how it will fit.
Old Jun 26, 2009 | 10:59 AM
  #309
I'll be doing some exhaust work either next week or the week after, will take some pictures then.
Old Jun 26, 2009 | 11:09 AM
  #310
RicoG35x's Avatar
Yes! pics please... I have the same year x you do.. say it's do-able brother!!
Old Jun 27, 2009 | 12:21 AM
  #311
TurTLe*'s Avatar
are there no LA AWD test subjects to make this easier for EVERYONE?
Old Jun 27, 2009 | 10:01 AM
  #312
Who would have an X in LA? Just playin, I hope there are.
Old Jun 27, 2009 | 10:53 AM
  #313
Hydrazine's Avatar
X's are very rare in this area. Snow and black ice are practically non-existant around here.
Old Jun 27, 2009 | 11:10 AM
  #314
Is it that hard to take my word for it?
I promise you I have a first gen G35X.
And I promise you I have the Motordyne XYZ pipe installed on my car.
Old Jun 27, 2009 | 12:06 PM
  #315
TurTLe*'s Avatar
its not your word we dont take, its just pictures > your word as of now. You can obviously see how actual pictures can overrule what anyone says.
