Battery + Brake (!) dash lights ON
Old Apr 14, 2009 | 10:54 PM
6MTFTW's Avatar
Holy crap! A steady ( ! ) means that one (or more) of your tires has low tire pressure...
Old Apr 14, 2009 | 11:07 PM
RADIOGUY21's Avatar
i had a bad alternator in my old altima throw the brake + battery light (standard Nissan indication of a fault in the charging system). When I checked for voltage it was putting out normal voltage. But when I had it tested on a machine it failed.
Old Apr 14, 2009 | 11:40 PM
Trbulnt's Avatar
May have had voltage...but the regulator may have been bad and may be overcharging the system. Or it may not be able to maintain the required amp draw for the vehicle.
Old Apr 15, 2009 | 11:54 AM
kwiniarz's Avatar
I dont have tire pressure sensor for my car.
Thanks everyone, alternator is going in tomorrow. I'll report back
btw dealer wanted 475 for the alternator, asked my friend and got one for 290 (non refurb), this is canadian.
Old Apr 16, 2009 | 05:21 PM
kwiniarz's Avatar
got the new alternator in, still on.
any suggestions?
Old Apr 17, 2009 | 07:07 PM
MarkG's Avatar
Wow, I thought that would have done it. Have you checked the battery terminal connections?
Free bump.
Old Apr 17, 2009 | 07:12 PM
WILLIE BEANS's Avatar
Originally Posted by 6mtftw
holy crap! A steady ( ! ) means that one (or more) of your tires has low tire pressure...
yuh i had it on put air in my tires and it went away .. Right after ..
Shrugs shoulders to other lights ..
Old Apr 17, 2009 | 08:09 PM
kwiniarz's Avatar
Free bump.
Yup, first thing i check, i'm giving up. Everything actually working fine except for the damn lights, i'm thinking of just pulling the lights out of the dash.
Old May 10, 2009 | 12:31 PM
nightwing17's Avatar
I'm getting the same thing, did the new alternator fix it?
Old May 10, 2009 | 07:24 PM
Blue Dream's Avatar
I drove ttrank's car solo
^ Please read through the whole thread before you ask a question that has already been answered. Doh!! Post #20 in case you miss it the second time around. ;(
Old May 10, 2009 | 09:10 PM
RADIOGUY21's Avatar
start by getting your alternator tested.
Old Jun 4, 2009 | 08:47 AM
kentonpepper's Avatar
Im getting the same problem. Just started yesterday. It was flashing but now they are on solid but very dim. I'm going to try a new battery later.
Old Jun 4, 2009 | 08:55 AM
geew1z's Avatar
Originally Posted by fluxcapacitor
i've always wonder what does the ( ! ) mean?
That is the normally the low air pressure warning.. although it would turn on if one of the sensors is bad too.. Nissan's version of tpms only monitors the tires in motion and after filling them with air, might still be on for a few miles..
However if the battery light is on too then Idk, is the battery a low maintance or sealed? If low maint, check each cell to make sure enough fliud is in them..
Old Jun 4, 2009 | 09:07 AM
geew1z's Avatar
3 milliseconds of googling and here's your answer:
Those lights being on indicates a bad diode pack inside the alternator. The alternator itself is probably still charging and you can drive it like this for a long time. The only thing is, if the alternator dies, you won't know it. Replacing the alternator will correct this.
from: http://autorepair.about.com/library/faqs/bl705d.htm
Maybe your replacement is shot too or is it possible the diode pack is seperate from your alt?
Old Jun 4, 2009 | 09:29 PM
  #30
Wannabe6MT's Avatar
-MN G Crew-
My TPMS sensor ligh (!) comes on when im driving for awhile on the freeway as well. Wierd, huh? Factory design flaw.
chinee
Jun 10, 2024 07:48 PM
wonderizm
Sep 24, 2015 03:09 AM
myaso
Lighting
Jul 22, 2015 10:34 PM
