G35 Sedan Suspension Picture Compilation Thread
Old Nov 10, 2019 | 02:34 PM
  #1666
SeoulChicagoSFR's Avatar
2 year update
Pictures are taken from this past summer
I was straight pipe from the test pipes here. I hit a raised manhole cover and it broke my exhaust at the ypipe. I couldn't avoid it due to heavy traffic on the right and a curb to my left
Black Obsidian is hard to keep clean
My 1st gen X on oem 17s and chopped springs (don't do it your back will hate you) but handles and stops better, no 4x4 wheel gap either. My clearance is about 2-3 inches to the bottom of the side skirt, to the bottom of the exhaust it's a little less. I have a off brand cai, 1/2 plenum spacer, test pipes, vhr racing ypipe w/ no heat shield, and a 2.5" muffler delete into a 2.75" single slant exhaust tip. I also have full led lighting interior, license plate, reverse light. 8000k HID Xenon headlights. Limo 5 percent tint on the rear and 50 tint on the front. blacked out side markers and front grill. Square 225/50r17 Hankook Ventus Noble1 S2 tires w/ 25mm + 3mm spacers (in these picture I was 25+3 front & 25mm rear). The car sounds deep especially around 2-4k. It gets louder and less deep at higher rpms but absolutely no rasp. Some small pops after letting off every now and then. My build was a budget build because I didn't want to spend on mods that were worth more than my car. Just wanted it to look, sound, turn and pull better while still looking like a sleeper. Currently running in full rwd mode.
Next mods in mind are equal length headers and a sc14 supercharger. I can keep the budget build going and make more power. I prefer a turbocharger but I don't have have the fab skills or tools to make my own custom turbo hot side
Old Nov 10, 2019 | 02:45 PM
  #1667
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I'd like to see how well an SC14 fits in the already cramped engine bay on the G35, definitely interested though since you can pick those up for a reasonable price and rebuilding them is simple as well.
Old Apr 14, 2021 | 02:17 AM
  #1668
Gemichi's Avatar
Base model G35
Now that it has been years and feels like many companies have stopped making suspensions for this model. What are best budget shocks I can get? specifically rear shocks. I'm looking at KYB, but would be nice if there is something better that I do not know of.
Old Apr 16, 2021 | 12:35 PM
  #1669
cleric670's Avatar
BANNED!!!
KYB Excel G is your budget minded (while still name brand) shock/strut (roughly $350 for all 4). A better twin tube option is something like the Tein endurapro PLUS line (roughly $550 for all 4). If you have ANY thoughts of putting the car on the track, or if you drive it pretty hard then I strongly suggest stepping up to a monotube like the Bilstein B6 non adjustable (about $800) or the adjustable Koni yellows (about $950).
The Tokico blues that used to be the budget OEM replacement have been long since discontinued so don't bother looking for them anymore.
Old Apr 18, 2021 | 12:38 PM
  #1670
Gemichi's Avatar
Base model G35
Glad I still have some options! mostly I'm want to replace the old ones since they are getting a bit bouncy. While also wanting to get some improvements over handling. I saw the Bilstein B6 and they seem pretty nice, but for my budget, seems like the best I can afford is the Endurapro Plus unless I'm only upgrading the back shocks for now since they are more bouncy than the front.
Old May 6, 2023 | 01:37 AM
  #1671
RastaBoyG's Avatar
Pretty much modified everything tastefully no ebay junk just driver comfort/performance mods mainly.
03 Canadian G35 Sedan RevUp/6Spd swap Drift car
Custom S14 front knuckle conversion with angle kit on Godspeed pro coil overs. Adjustable everything from a few name brands and Soul Function chassis bracing. I'll get more pics of everything next drift event!
Old Jan 3, 2024 | 11:50 PM
  #1672
Bdub35's Avatar
5 Year Member
G35 sedan
2003. On a set of Raceland Ultimos coil overs. Front has ISR upper control arms 20x9 tires 215-35 offset 35 with 15mm spacer
Rear complete truhart arms 20x10.5 tires 255-30 offset 38 with 18mm spacer
Old Jan 3, 2024 | 11:54 PM
  #1673
Bdub35's Avatar
5 Year Member
G35 sedan
Cars a little dirty
Old Oct 16, 2024 | 05:25 PM
  #1674
GEE35415's Avatar
BC racing extreme low coilovers w/ 12k front 10k rear spring rates. Godspeed upper camber arms and energy suspension inner lca bushings. Megan racing front strut tower bar.
Edited to add: Completed the rest of the front suspension lca/compression rod bushings with energy suspension, new outer tie rod ends and a rear Megan racing sway bar.
precocial
Media Share G35 Sedan V35
4276
Oct 16, 2024 05:42 PM
g35guy86
Nov 18, 2022 10:38 AM
LoSt180
Aug 23, 2018 08:16 PM
akogan79
Jun 16, 2013 09:31 PM
acee
Steering & Suspension
Nov 22, 2012 08:47 PM
You have already rated this thread Rating: Thread Rating: 4 votes, 4.75 average.
