G35 Sedan Suspension Picture Compilation Thread
Old Jun 12, 2012 | 12:48 PM
  #1171
aogram's Avatar
Originally Posted by MPG35fiend
sick! go moar low!
Agreed, +1
Old Jun 12, 2012 | 12:51 PM
  #1172
SDGenius's Avatar
^or more tire
Old Jun 12, 2012 | 08:50 PM
  #1173
RaheemG35's Avatar
[IMG] Name:  DSCF1517.jpg
Size:  142.4 KB Name:  DSCF1518.jpg
Size:  65.5 KB Name:  DSCF1519.jpg
Size:  98.0 KB Name:  DSCF1520.jpg
Old Jun 16, 2012 | 10:02 AM
  #1174
DVG's Avatar
DVG
Anyone with the G/Z combo with no camber kit: Please tell me what your experience has been like as I am planning on doing this
Old Jun 16, 2012 | 10:28 AM
  #1175
ryanm8's Avatar
I have a full Z suspension with no camber kit. No issues at all. I was able to get an alignment to 350z specs and my tires have held up fine.
Old Jun 16, 2012 | 06:58 PM
  #1176
Texasscout's Avatar
I have a sedan, unrevised Z springs in front and Coupe springs in back. After an alignment, the camber is off by 1.2 + degrees. I do get wear on the inside of the back and front tires. I get about 25,000 miles out of a set.
Old Jun 16, 2012 | 08:00 PM
  #1177
meG35man@yahoo.'s Avatar
Great looking and well balanced
Originally Posted by Antoniog35
Whats Ur wheel specs and what suspension ?
Your machine looks to be one of the few that I have seen that looks like you can drive it without scrubing the wheel wells. The rim & tire combination are very balanced. Beautiful rims! nice tread pattern. What inch rim, and tire size combo, fronts and backs?
Old Jun 16, 2012 | 09:26 PM
  #1178
sandaluv's Avatar
Im running that combo. Im happy with the look. I think the gap looks pretty even compared to other spring kits but just like many have said you will probably want to go a tad lower after running this setup for a while. For me, this was an inexpensive way to mod the suspension and improve the stance. I just rotated my tires and im getting uneven tire wear in the front. I did the alignment soon after the drop but there is no camber adjustment in the front so i knew this would happen. Rears look good though. I might do a front camber kit. But man are they pricey. Hope this helps.
Old Jun 16, 2012 | 09:43 PM
  #1179
DVG's Avatar
DVG
Thanks for the feedback so far, this would be an ideal setup for me, I have no desire at all to be low, I dont really care about fitment or anything, I just want it to look normal! The wheel gap is too damn big lol
I thought you were supposed to wait for the springs to settle before getting an alignment?
Also, is the 350z alignment suggested? Does it give you good handling & tire wear?
Old Jun 16, 2012 | 09:46 PM
  #1180
DVG's Avatar
DVG
Originally Posted by RaheemG35
[IMG] [/IMG]
Did you roll your fenders? The quarter panel looks a bit weird next to the rear bumper in your first and second picture
Old Jun 17, 2012 | 04:38 AM
  #1181
Picture.g35's Avatar
Eibach Pro Kit, Hp struts, spc rear camber.(FRESH OUT THE PAINT SHOP) (COILS SOON)
Old Jun 17, 2012 | 08:07 AM
  #1182
MPG35fiend's Avatar
spec on wheels?
Old Jun 17, 2012 | 09:12 AM
  #1183
RaheemG35's Avatar
Yes the fenders was rolled but they will be getting redone in the near furture.
Old Jun 17, 2012 | 09:49 AM
  #1184
sandaluv's Avatar
Sounds like this setup will be perfect for you. I forgot to mention i slapped some 20mm
Spacers front and back and this actually helped close the gap a little bit more. Depending on your wheel/tire setup, you might have to roll your fenders if you add spacers. As for the alignment, i waited a couple weeks to do it. The springs were used so i dont think there was much settling to be had. i dont know what a 350z alignment is. Are you referring to using Z specs for the alignment? And yes handling improved with the drop even though it was sport tuned stock suspension.
Old Jun 17, 2012 | 10:45 AM
  #1185
spec on wheels?
19x8.5 and 19x19.5. 20 mm space in front and ordering 15 for the rear. Tires 245/40/19 all around
You have already rated this thread Rating: Thread Rating: 4 votes, 4.75 average.
