Gear Selector is locked...need help asap
Old May 13, 2009 | 09:24 AM
ajg35's Avatar
I removed the console and radio last night to replace the radio circuit board and after reinstalling everything, the gear selector remained locked. THe only way I can shift out of park is by using the "key release" function.
Is there anything specific I need to inspect and/or that might be causing this? When the key is turned to the "on" position, and when I press on the brake, I can hear the clicking sound (relay) to release the selector, but I don't believe it's doing anything. Everything worked just fine before I tore into the car, so I am stumped as to what might be the problem. the last thing i want to do is drop it off at the stealer.
Any thoughts?
Old May 13, 2009 | 11:22 AM
pwebb's Avatar
there is a connector for the shift lock release.
plug it in.
Old May 13, 2009 | 12:07 PM
ajg35's Avatar
Where is the connector? I don't recall ever unplugging anything around the area and don't see anything unplugged. Isn't there a fuse for the "shift Lock" relase mechanism? The relay is working when I apply the brake, but nothing happens with the Shift Lock.
After doing a search, it looks like my problem might very well be due to a blown "Shift Lock" fuse. Any idea where the fuse is located? Is it a dedicated fuse locally or is it in the fuse box in the cabin or under the hood?
Old May 13, 2009 | 04:56 PM
ajg35's Avatar
anyone? Is there a dedicated fuse for the "Shift Lock" device? TIA
Old May 13, 2009 | 10:44 PM
ajg35's Avatar
nothing like answering your own posts...lol. It was a fuse on the lower kick plate. All is good!
Old May 19, 2009 | 10:25 PM
seankim513's Avatar
check the driver kick panel fuse.13 or brake. i had same issue.
Thebaws11
Jul 2, 2021 11:36 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
_evilMonkey_
2nd Gen (V36) Sedan
Nov 22, 2015 06:21 PM
Since 1983
Sep 19, 2015 10:26 AM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
