Need help with parking lights
Old May 17, 2009 | 11:08 PM
Gorg3ou5's Avatar
my parking lights and interior dash lights [ac controls,radio,etc] arent working...
i replaced my corner lights with some leds but i think the watts was too strong? maybe
i checked all my fuses and none is burnt...
anyone know whut it could be
Old May 18, 2009 | 06:38 AM
Blue Dream's Avatar
I drove ttrank's car solo
Did you check the fuse box in the engine compartment behind the battery? You've got to take out the battery, so it's a little work.
Old May 19, 2009 | 11:48 PM
Gorg3ou5's Avatar
need help stilllll
Old May 20, 2009 | 09:10 AM
geew1z's Avatar
LEDs take almost no power, so that is not the problem.. Did you unreplace those bulbs to see if the lights start working again?
I'd try that, if that doesnt work, you are gonna want to remove the fuses that could be suspect and actually look at the contact and see if it looks blown. If your not taking it out and just measuring continuity with it plugged in, the fuse could be bad, but make the slightest contact..
Old May 20, 2009 | 11:22 AM
FlSHRFun's Avatar
I've had this problem before. It's a blown fuse. Trust me...
This is the thread that let me know how to fix the problem:
https://g35driver.com/forums/audio-v...use-blown.html
I had to replace the fuse twice. Second time around, I realized, removing the battery isn't necessary. Just make sure you disconnect the negative battery terminal.
Just remove the battery cover, and half of the black plastic trim along the windshield... then squeeze your hand down behind and to the left of the battery and remove the black plastic box covering the fuses.
Replace that indicated blown fuse and voila. Parking lights are back on.
Mry
Mar 3, 2023 01:03 AM
11bEMT
May 27, 2022 03:13 PM
mtlruss
Dec 20, 2015 01:51 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
