Quote:
spell-check and punctuation fail.Originally Posted by kraziebone6988
ur right about it might get stolen but iv been living in my city my whole life i know ppl and if someone did it i would fid them and kill them but u can put insurance on the radio lol but there is a deductable for the insurance. my unit keeps shutting off and turns back on my itself i haver insurance so i think ium going to get a new one
Quote:
Yeah and he is going to kill someone for stealing his stereo. Originally Posted by codeflux
Blue Dream
I drove ttrank's car solo
close
- Join DateMar 2009
- LocationBy the sea, Tx
iTrader Positive Feedback100
iTrader Feedback Score(50)
- My RideG35 sedan w/ too much money in mods
Liked:1,488 Times in 1,223 Posts
Must be smoking the hippie lettuce. Trying to read his post was like trying to learn a new language.
Bose systems are engineered to only work well with each other. Each Bose application is custom designed for the environment it is installed in. Therefore a Bose system for a Maxima will sound like azz in a G35. The speakers are not compatible with aftermarket systems. They have a completely different ohm requirement, I just can't remember what it is. 2 ohms maybe. Bottom line if you're going to swap out your radio, be ready to swap out your speakers as well. Either the Bose speakers will not work at all, or they will sound like ****.
But you do what you want. Don't let us stop you.
Im almost positive that the bose is 2ohms, 4ohms is the standard. I have an aftermarket head unit and stock speakers, and it sounds decent. The trick here is the harnesses. You use the rca connectors if you have a 4 volt or higher pre-amp output, or you use the standard harness if your pre-amps are lower than 4. This is the reason so many people complain about the sound quality afterward. They use the RCA harness with a stereo that has to low of pre-amp outputs.
Wannabe6MT
-MN G Crew-
close
- Join DateMay 2007
- LocationFargo ND/Eden Prairie MN
iTrader Feedback Score(10)
Liked:205 Times in 157 Posts
Iv got an Alpine IVA-W205 headunit in my 05 sedan no bose. It sounds OK. I added a sub so that helps, but iv often thought about upgrading the speakers.
Any recommendations? I love music, and i love good, clear, deep sounding systems..
Yeah, look into CDT audio.. If you really want good sound, get component speakers and an amp to drive them.. and dont bother with rear speakers other than a sub..Originally Posted by Wannabe6MT
Iv got an Alpine IVA-W205 headunit in my 05 sedan no bose. It sounds OK. I added a sub so that helps, but iv often thought about upgrading the speakers.Any recommendations? I love music, and i love good, clear, deep sounding systems..
Quote:
If you're using the amp in the radio, it might sound great until the amp dies.. Or did you do something else? Also, did you use the metra kit with the hvac controls? If so, how is the fit/finish?Originally Posted by RyanJones
Put a double din in my sedan its powering the speakers fine and sounds great
I have a pioneer double din in my sedan. Works fine with the factory Bose sound system after i messed with the levels a little. No matter what at some point changing speakers amps and sub would be the best but of money is an issue stock speakers work fine for a good amount of time. I have the metra harness and did the install all myself. For those that don't know the Bose subwoofer does work with an aftermarket head unit but the way that its wired with the metra harness it acts like another rear speaker. Which can be fixed if your head unit has a subwoofer pre out. I've installed aftermarket units with factory speakers and subs on a few cars. Any questions pm me
