Black housing lights
Old Jun 5, 2009 | 01:48 AM
squabzter's Avatar
I'm wondering where you guys got your black housing headlights! I busted the tab on mine and they're all foggy and such so I wanna up grade. Please let me know where you found them!
Old Jun 5, 2009 | 07:32 AM
rlea27's Avatar
Ohio G Club Member
Most of the ones you see if not all have been painted. There are a few DIY's floating around here if you search for them. To sum it up you take you factory HL's throw them in the oven to heat up the sealant/glue which lets you pull the lens away from the housing allowing them to be painted. The fogging issue is easily solved with Meg. PlastX or Mothers Plastic Polish.
Old Jun 5, 2009 | 08:20 AM
G35Papa's Avatar
https://g35driver.com/forums/lightin...eadlights.html
Old Jun 5, 2009 | 08:39 AM
GT-ER's Avatar
I got mine from ebay.
Old Jun 5, 2009 | 09:07 AM
ttrank's Avatar
Grocery getter
Paint
Old Jun 5, 2009 | 10:56 AM
squabzter's Avatar
do you have the HID's? How can I tell which ones will work?
Old Jun 5, 2009 | 02:33 PM
ttrank's Avatar
Grocery getter
Ebay ones are not for HID's.
Just paint them...
Old Jun 5, 2009 | 02:40 PM
GT-ER's Avatar
ttrank is correct, ebay ones do not work with oem hid setups. I do not have HID's.
Old Jun 5, 2009 | 02:43 PM
ttrank's Avatar
Grocery getter
There a good idea if you are going to do a projector retro and can't deal with the down time without lights.
Old Jun 9, 2009 | 10:23 AM
GraphiteGSdn's Avatar
Just paint them...
I am looking for a temporary lighting solution while I take my stock HIDs out to paint and install projectors. You mention the ebay ones will not work...
Is it because the HID harness will not plug into the halogen housing? Or is it because they are only available for the 03-04? I looked on ebay for 05-06 sedan lights to use meanwhile but they are rare and when they do come up they are pricey...there's ONE on there right now for a BIN of $200 - and it has broken tab! That's a bit too much when I can buy a pair for less than that.
Any ideas you could provide? Thanks for your input!
Old Jun 9, 2009 | 01:20 PM
seankim513's Avatar
don't get ebay one all black housing for non hid and very poor seal.get used one and take out use oem flat black paint about 5 times .it will works if you use oven 200.f for 10min and take a part. make sure only 200.f not more than that .
Old Jun 9, 2009 | 05:58 PM
Mustang5L5's Avatar
What do you guys do for lights while you are doing this??
I want to paint my housings....but i always need my car. I don't want to rush and do a half-*** job either.
Old Jun 9, 2009 | 06:04 PM
G35Papa's Avatar
Take a weekend day and do it all in one day.
jsimonk
Dec 22, 2023 03:49 PM
Jusseth
Sep 13, 2020 12:25 PM
djreinx
Engine - Electrical
Dec 10, 2015 01:48 AM
laksjd84
Accessories
Jul 24, 2015 12:37 PM
