tail light upgrade
Old 06-22-2009, 11:01 AM
DaveB's Avatar
Originally Posted by blkonblkGsedan
i blacked out the chrome on my car the same way is easy, gloss black vinyl on door handles and flat black vinyl on window trim
That's how my chrome was blacked out as well. Recently, I removed the vinyl from the window trim because I didn't like how bland it made the car look. I don't like how wide the chrome pieces are around the windows so I took some pinstriping and essentially made the chrome window trim 3/8" narrower. It looks much better now.
  #32
Old 06-22-2009, 11:04 AM
Mustang5L5's Avatar
Nice i'll have to give it a try. Where did you guys get the vinyl from?
  #33
Old 06-22-2009, 11:08 AM
OKStateG35's Avatar
Originally Posted by DaveB
You're correct. It's simply how the light hits the housing.
Cool, so is the plastic in the turn signal amber or clear if you are looking at it from the rear without your signals on?
  #34
Old 06-22-2009, 11:12 AM
DaveB's Avatar
I used 2" wide high end electrical tape vinyl. You could always order from a vinyl shop. If I did it again, I'd source some 4" wide vinyl so it's easy to do the rear door rail where it curves forward. That's the hardest part.
  #35
Old 06-22-2009, 11:15 AM
DaveB's Avatar
The signal housing is red when the signal is off. When they're on, they're amber. In certain sun angles, the signal portion may look pink, slightly pinkish clear, or sometimes slightly amber.
I got mine from Tony at Riverside. They were $300-330, if I remember correctly. They're cheaper than buying the US OEM tails.
  #36
Old 06-22-2009, 11:27 AM
OKStateG35's Avatar
Sweet, thanks. I might order some of these and sell my US OEM ones to recover some of the cost.
  #37
Old 06-22-2009, 02:11 PM
OKStateG35's Avatar
Well, I PM'd Tony at Riverside Infiniti and they have them in stock ready to ship. I went ahead and ordered a pair of the 05-06's. Assuming I like the JDM's, my US OEM's will be up for sale shortly.
  #38
Old 06-22-2009, 02:56 PM
ttrank's Avatar
Grocery getter
Let me know what you want for them. I am looking for a new set of 05/06's because the paint on mine are all messed up and it's going to be a huge pain to strip all that paint down.
  #39
Old 06-26-2009, 10:32 AM
RicoG35x's Avatar
Originally Posted by TwilightBlue
Be very careful when getting tail lamps from places like ebay. They should say Koito Japan Nissan on them. Koito is the supplier of the tail lamps for nissan, both JDM and USDM.
+1 on the JDM Tails. I have the 03-04 version. While I like the 05-06 JDM Tails, I chose these because my car is an 04.
Very nice.. I really like the amber lenses on this setup... I kept the OEM amber side markers because I like the amber contrast with the black body.. versus clear.. although I have a set of the clears... I'm diggin' the amber for now... but THIS would blend the amber/black contrast nicely front to back!
Where did you source JDM 03/04 rear assemblies from..?
I'll be adding these for my mods to do list for SURE!
  #40
Old 06-28-2009, 01:15 AM
DaveB's Avatar
JDM tails in action:
  #41
Old 06-28-2009, 11:27 AM
NjMatteSedan's Avatar
Mustang5l5 you can get black vinyl sheets on ebay tha u can use for the door handles. I would have a professional do it if u don't have much experience with decals, for the window trim I got blackout tape from pepboys which is the same material and shade as a flat black vinyl sheet, I got a flat black vinyl sheet from ebay also cuz the blackout tape wasn't wide enough to do the rear part by the back window where it curves
  #42
Old 07-28-2009, 05:20 AM
SilverGthang's Avatar
Im not a big fan of the amber... so I think I am going with the upgrades from g35parts.com... My question is that is there a DIY for this upgrade, or do i just remove the trunk covers and the screws are right there and i just swap out the lights?
  #43
Old 07-28-2009, 08:47 AM
RicoG35x's Avatar
I've had no luck sourcing these JDM Amber tail lights.. so I guess I'll stick with OEM... I kinda like the red.
  #44
Old 07-28-2009, 09:26 AM
OKStateG35's Avatar
You shouldn't really need a DIY just to swap out the tail lights. You just pop off the interior plastic pieces, pull up the pad covering the floor of the trunk, unbolt and unplug the lights and install the new ones. Should only take you about 15 minutes or so.
  #45
Old 07-28-2009, 09:28 AM
OKStateG35's Avatar
Riverside Infiniti special orders the JDM version. It's kind of hit and miss whether they have them in stock or not. Go with what you like, but the JDM's looks really nice on the car.
Quick Reply: tail light upgrade
