Will these wheels fit??
Old Jun 22, 2009 | 12:19 PM
B.G.'s Avatar
Ive searched a little I think I may be good. But just for assurance I would like to check if either one of these setups would work on my 06 sedan.
19x8 20mm front 19x9.5 32mm rear
19x8.5 30mm front 19x9.5 25mm rear
If neither of these would work as is, could they be run w spacers? Also, I plan on H tech springs. Would this cause rubbing? Thanks for the help!
Old Jun 22, 2009 | 12:37 PM
G SEDAN's Avatar
the first option will work with the right size tires and rolled fenders but I wouldn't run it. Reason being....if you're going to go aftermarket....might as well go for a size that are wider than 8 inches
the 2nd one will also fit if you wanna start messing with the negative camber, stretched tires, and cut fenders and such.....personally....I don't like that route either.
Old Jun 22, 2009 | 12:40 PM
G SEDAN's Avatar
the rear fitment in both setups are the culprit for the uncertainty. it's aggressive for the sedan, but of course it's been done already by some of the crazy cats on here
Old Jun 22, 2009 | 12:41 PM
B.G.'s Avatar
Dang, thanks for the honest response man...Guess my pursuit for wheels continues
Old Jun 22, 2009 | 12:45 PM
G SEDAN's Avatar
19x8.5 +30 and 19x9.5 +35 would be very nice if you can come across that setup, I just assumed you were the average joe that wants plug and play no fitment problems. Anything can be done if you are willing to go through the lengths.
My knowlege is very basic in this....if you want to hit up an expert.........gdup35sedan is the man.
Old Jun 22, 2009 | 02:22 PM
FlyingLumpia's Avatar
G Sedan quoted himself. LOL
Old Jun 22, 2009 | 02:52 PM
ttrank's Avatar
Grocery getter
That's funny there!
Old Jun 22, 2009 | 02:54 PM
G SEDAN's Avatar
LOL not only do I qutoe myself, when I bump my threads I put "bump for a homie!"
WHY? Cuz I'm my own best friend LOLOL
Old Jun 22, 2009 | 03:42 PM
B.G.'s Avatar
Yeah I kind of am just looking for a plug and play... Not really looking to do any fender rolling/pulling etc etc... I have one more setup that im looking at
19x8 45mm front
19x9.5 35mm rear
Would that do
Old Jun 22, 2009 | 05:51 PM
G SEDAN's Avatar
19x8 45mm front
19x9.5 35mm rear
Would that do
what that would do is have a really sunken in front wheel fitmen and a flush rear wheel fitment.
the red is a bad thing, not a good. LOL
keep lookin!
Old Jun 22, 2009 | 06:14 PM
az1anbeethoven's Avatar
a good setup for most people that don't want to mess around with excessive camber and all that stuff is:
19x8.5 35mm front
19x9.5 42-45mm rear
Old Jun 22, 2009 | 06:16 PM
cremaster's Avatar
19x8.5 35mm front
19x9.5 42-45mm rear
that's what i have. if you drop the rear you won't need to roll the fenders if you go w/ 265s.
Old Jun 23, 2009 | 01:43 AM
gsRt5's Avatar
Ur a MOG?
Old Jun 23, 2009 | 03:34 AM
G SEDAN's Avatar
what's a MOG
Old Jun 23, 2009 | 04:10 AM
TurTLe*'s Avatar
on the topic of will it fit, 18x 8.5 + 50 offset all around, paired with 245/45/18, would that work without trouble on the sedan.
