"Whoosh" noise when at 2.3-2.5k RPM
Old Jun 29, 2009 | 09:47 AM
ProfanityPete's Avatar
Hey, in the past few weeks I've noticed this whoosh noise (as my girlfriend puts it) JUST in the 2.3-2.5k RPM range. I can really only notice it when I'm going slow, I don't know if that's because of the road noise at higher speed, or if it stops. It's actually quite loud, I rolled a window down yesterday and was surprised at how loud it was.
I'll shoot a video today of it, but do any of you have a clue as to what it could be? It's nothing like the sound from the popcharger, thats more of a whistling sound and it's more at 2.5-3k RPMs. The only other thing I can think of is the VQ exhaust system, but I didn't noticed it until a couple months after I installed it.
Old Jun 29, 2009 | 11:12 AM
STCLAIRWEST's Avatar
Does it only happen when you start your car? Or does it happen all the time?
Old Jun 29, 2009 | 11:13 AM
I notice it more when the car is warming up, I think it's there all the time, just lighter after the car warms up. I'll let you know for sure later today though.
Old Jun 29, 2009 | 11:35 AM
Ohh...cause thE ABS does a check when you start your car in the morning and drive a little and it makes a wooosh sound too.
Old Jun 29, 2009 | 11:40 AM
yeah, I don't think it's that. It's really like a rush of air coming out of somewhere in the mid to rear of the car. Sounds like a hole in the exhaust without the excessive noise and it's only at that certain RPM range.
Old Jun 29, 2009 | 11:57 AM
GGGGGGGG's Avatar
have you check for leak in the exhaust to see if the clamps are tightened according to the spec?
Old Jun 29, 2009 | 12:00 PM
Yep
Ya im guessing it must be a leak in your exhaust
Old Jun 29, 2009 | 12:03 PM
You think so? Even just at those RPMs?
Mmagic76's Avatar
Spacer, most ppl who have a spacer seems to have this whoosh noise. There was a thread about this a while back.
Old Jun 29, 2009 | 12:05 PM
Only one problem with that... I don't have a spacer
Old Jun 29, 2009 | 02:05 PM
Mustang5L5's Avatar
If it was an exhaust leak it would tick. One way to check is put your hand on the tailpipes (when cold!) and seal it. If there was a leak you'd get a loud tick.
You don't have a mechanical engine fan do you? Was that only early 03's?
Old Jun 29, 2009 | 02:25 PM
I don't think I have a mechanical engine fan, but it doesn't really sound like it's coming from the engine either
I'll go try putting my hand over the exhaust pipe
Old Jun 29, 2009 | 03:29 PM
Put a piece of cardboard over the pipe to seal it, and I heard no tick, just a very light hissing sound where I didn't quite completely seal it.
Old Jun 29, 2009 | 05:21 PM
Progression's Avatar
It could be the Bushings
When I release my A/T into gear the car unwinds like those matchbox cars. The longer I keep it the car off the faster it starts e.g. it pulls my car into gear. It seems I go faster than 5 mph once into gear.. kinda crazy... then when it finally winds down I hear that sound as well... I'm thinking it has to do with the Bushings connecting to the compression rods seen here:
https://g35driver.com/forums/brakes-...otal-crap.html
Here's also the TSB I found today regarding it:
http://x.infinitihelp.com/forum/loca...6&sort=d&pp=12
I'm going to take it into the shop the end of this week and will let you know what happens.
