lowering springs question.
https://g35driver.com/forums/brakes-...w-updates.html
this is one of our stickied threads in the suspension sub-forum.
if you are in the market and want to see a comparison of whats out there, how much they'll lower your vehicle and if they'll make your ride stiffer/softer (spring rates)
As a rule of thumb, if you lower your vehicle by more than 2 inches you will defninitely need front and rear camber/toe kits to get your alignment back within factory spec (keeps your tires from premature wear). You may also need new shocks/struts. OEMs shocks/struts will fit but they will go out much faster when you're lowered. Also, if you have 60K plus miles and you are lowering your vehicle, you might as well replace them at this point anyway.
Just put my 350z revised suspension up for sale. Includes coupe springs for an even drop.
https://g35driver.com/forums/steerin...ml#post5860597
Terry_G35
Sep 10, 2015 08:17 PM
