front brake pads installed *question*!!!
Old Jul 29, 2009 | 09:59 PM
maciejk's Avatar
Originally Posted by blownvert
why would someone do there own oil change if its like $20. why hassle in buying oil what you saving $5? I dont have a jack. my wheel shakes when i press on the brakes at higher speeds with steering wheel vibration. the pads are not on right. is that what is causing that?
why? to avoid fvck ups like u just encountered with your brakes, i'd do my own but car's still under warrenty i gott do them every 1000-1500 km not miles, a 10 minute oil change is garbage since a lot of the dirty oil is left over, when i did my oil changes in my old car i let it drain for 2 hours and it was still dripping, then i would pour a bottle of cheap **** oil to flush most of the dirty oil out, plus u never know if they really change your damn oil filter unless u mark it, that's why
Old Jul 29, 2009 | 11:31 PM
DaveB's Avatar
Originally Posted by pwebb
you only need a 14, and you only need to take the caliper off.
leave the bracket installed. no need to compress the piston.
Yep, 14mm socket or wrench is the only tool needed if you're simply adjusting the pads. You remove the 14mm slider bolt, flip the caliper up, work on the pads, and reinstall the slider bolt with about 25 ft/lbs.
Working on these cars is not rocket science. About $150 spent on two cheap 14" to 16" jacks, one set of jack stands, 3/8" metric socket set and rachet, a few extensions, an 18" breaker bar, a set of metric wrenches, a set of screw drivers, a flash light, a plastic pan and you can do most all maintanence projects on this car.
Old Jul 30, 2009 | 08:10 AM
Mustang5L5's Avatar
Exactly. Has nothing to do with money. It's about making sure the job is done right and up to my standards. It could cost me MORE money to do my oil change myself, but at least i know what oil and filter go into the car, the oil filter is put on tightly (or not too tight), the drain plug is torqued correctly, and the underside body plastic is reinstalled correctly without missing bolts. It will be a cold day in hell before I ever let someone do an oil change on my car.
I did my brakes not too long ago. Took me an hour each side. Job was done once, and done right with anti-seize on the backside of the rotor, and brake caliper grease on the pad contact points. I even went as far as to paint the calipers up and clean everything up. Brakes are easy...and I have peace of mind knowing they were done correctly.
Granted i know everyone doesn't have the mechanical abilility or tools to do some stuff, but for some of the simple stuff it might be worth it to try or learn.
Old Jul 31, 2009 | 01:42 AM
David.A.C.'s Avatar
Thumbs up
Originally Posted by Mustang5L5
It's about making sure the job is done right and up to my standards. It will be a cold day in hell before I ever let someone do an oil change on my car.
Totally agree
kinetek
Aug 3, 2015 04:25 PM
sahizzle110
Jul 29, 2015 11:36 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
wojowojo16
Jul 27, 2015 09:57 AM
emorehs
Jul 17, 2015 09:45 AM
