driverside A-pillar leaking?
Old Oct 6, 2011 | 04:36 PM
AARONHL's Avatar
Same problem here. Only happens once in a while on each side.
Old Jan 21, 2012 | 03:35 PM
jdubbyap's Avatar
I'm having this issue as well. I took off the interior piece that runs between the driver side door and the windshield and inspected the leaky area while someone was pouring water down the drain around the sunroof. I didn't observe the first leak. I did see where the drain hose ran inside the frame of the A-pillar and the water was running out behind the front drivers side tire like it was suppose to. There appears to be a white fabric of some sort just behind the headliner where the leak is occurring. The leak doesn't occur every time it rains.
Has anyone came about a resolution for the issue?
Attached Thumbnails driverside A-pillar leaking?-interior-piece.jpg   driverside A-pillar leaking?-headliner.jpg
Old Jan 25, 2012 | 11:20 AM
jdubbyap's Avatar
Any other suggestions on what could be causing this? I have taken it to a local body shop and they cannot duplicate the leak. I called a local Infiniti dealership and they are dead set on it being the drains for the sunroof. They suggest that I blow air through the drains to remove any slight blockage(s). I'm afraid that if I spray compressed air through the drains that something will get disconnected. Thoughts?
Old Jan 25, 2012 | 03:43 PM
jin22gt's Avatar
My update:
I posted this thread in 8/2009.
It was a one time thing for me! This never ever happened again.! so far.....
Old Apr 11, 2014 | 05:12 PM
nable's Avatar
20 Year Member
leak in sunroof 2004 G35 Sedan
My headliner was getting wet checked the normal items made sure sunroof was closing properly [alignment] this was ok, checked drain lines not plugged and flowing properly, checked seal there is slight leakage but the drain line should take care of the leakage that's what they are for. Took car to dealer and the problem is the sunroof track. Near the front of the track under the plastic wind defector on the side window side of track is an 'overlap' seal there is one on each side of the sunroof track. This is where the front piece of the track is joined to the rear section. This joint is factory 'fused' does not appear to be welded. the leak is at this joint. You can confirm this by removing the headliner in the area of the A frame then pour some water into the the sunroof track. If this joint has separated like mine water will come through the seal and run down the A pillar. The fix is to replace the sunroof track. Dealer quoted a price of $3300 for parts/labor.
Old Mar 27, 2015 | 08:36 AM
BlueBelleG35x's Avatar
This just started happening to me yesterday, water leaking slightly down my apillar(driverside) Grrrrrr.. pulled the apillar off an saw wherr it was wet an slightly coming fro.. Just read all the replys an suggestions an hope to go one of them is my solution. If anybody emse has a solution please post. Will feedback my results!
Old Apr 2, 2015 | 11:18 AM
B T's Avatar
B T
I ran metal wire as well as a water/bleach solution through both forward sunroof drain lines and haven't had it happen since. Weed whacker line does real well to run through after the metal wire.
Old Apr 2, 2015 | 12:23 PM
Found my leak ! Top corner of the windshield on the driver side ! Poured water down the seam and there came the water into the a pillar!
Old Oct 16, 2016 | 08:56 PM
BillA's Avatar
How do you remove the pillar trim
Old Oct 17, 2016 | 06:57 AM
Blue Dream's Avatar
I drove ttrank's car solo
Just carefully pull it off from one of the sides. It's just held on by clips.
Old Nov 30, 2016 | 03:44 PM
stevied's Avatar
same here. replaced it and all is well.
Old Dec 1, 2016 | 12:43 AM
neo_anderson302's Avatar
check the seam seal. Mine leaked after a windshield replacement. I just used some urethane.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
KallDay86
Jan 8, 2016 12:42 AM
hrdwirk1
Oct 2, 2015 06:34 PM
NyCrAzY
Oct 1, 2015 09:19 AM
vamarris
Sep 26, 2015 12:56 PM
