Leaves in the engine.
Hello so i just finished washing the car and wiping down the engine bay when i noticed there was a rectangular hole right below the engine cover where the timing cover is. I bust out a flashlight and find a lot of leaves in there. Anyone else notice this? Is there a way where I can remove all those leaves?
Not my engine bay but this would be easier to see where its at.
If you have access to an air compressor I would try blowing the leaves out that way. Shop vac might also help.
??? first post mentions valve covers and points to timing cover... 2nd post says blow it out the back its just the firewall and top of transmission, but its actually an ENGINE behind there
Then suggestions of chewing gum and a stick and some other cr@p... wtf is this thread???
Let's just trade engines, zero leaves over here. Must be a defect, you don't need that in your life.
(edit) nvm joke fail that's not your motor.
1/2 way useful suggestion: Buy a can of compressed air w/ the straw on it, and try to blow the leaves out.
I doubt very seriously the leaves will cause any damage to your car, but I have not seen any shop manuals on how this engine is assembled so I dont even know what's in there.
brianuc4
19
Apr 10, 2020 02:12 PM
FreshVQ
Sep 30, 2015 01:41 PM
