Z Suspension on sedan question
Old Jul 31, 2004 | 02:54 PM
alfapwr's Avatar
Re: Z Suspension on sedan question
One inch in front, Half an inch rear. Best thing I ever did to my car !!!
Dan
Stevenson Ranch, CA
2004 6mt Sedan: Black on Graphite.
Just splash guards and trunk mat - NO OTHER USELESS CRAP !!!
Old Jul 31, 2004 | 02:57 PM
Samstag's Avatar
Do you have any camber issues?
Old Jul 31, 2004 | 02:58 PM
Gsedan35's Avatar
1" When I first installed it I measured 1 1/8" in the rear. But after remeasuring it I now have 1" all the way around, go figure.
Here are some pics of how it looks on my car.
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
Old Jul 31, 2004 | 03:02 PM
Gsedan35's Avatar
The front will just be out of coupe alignment specs, set the rear accordingly. These cars reward you for not going too tame on alighment specs and it will punish you if you go too tame, something I learned the hard way.
Edmund Burke
G35 6mt
Old Jul 31, 2004 | 03:44 PM
Samstag's Avatar
So if I understand you correctly, the front will be out of spec, but close enough? And the back is close enough to adjust back in tolerance? I've got a sedan also.
Old Aug 2, 2004 | 11:12 AM
3point5SE_Auto's Avatar
I dunno, I dropped mine on an 03 Z suspension and I have some "tuck" in the rear. I will take some pics today or tomorrow and post em
the tuck is noticeable with a full tank of gas. At a quarter tank it is a "perfect" drop.
I think it is dependent on factors such as age of the suspension and driving techniques as to how far she settles
Better Life thru Chemistry
Black on Black 03.5 Sedan 6MT - Goodyear F1 GS-D3's 225/55/17, Custom Intake Tube, '03 "Z" Suspension, Magnaflow resonator, 6 Wire 4 Guage Grounding Kit
Old Aug 2, 2004 | 12:15 PM
Hey_Ya's Avatar
Jays_G - Check with Jran76 (I think that's his name). He had a Z with the Nismo and swapped it out and put it on his G sedan.
Old Aug 2, 2004 | 02:31 PM
blackonblackG's Avatar
with stock rims and Z suspension i had 3.5 finger gap front and 2 finger gap rear, now with my wheels/tires (245/45 18) i had 2 finger gap front and 1 finger gap rear.
Old Aug 2, 2004 | 10:38 PM
BrianV's Avatar
http://www.brianv.net/g35
Stock 17's with 04 Z suspension. Best thing I've done to my car as well.
04 6MT Sedan - Z Tube, K&N Drop-In, 04 Z Suspension
Old Aug 6, 2004 | 09:44 AM
andyranck's Avatar
There's a little tuck on my rear as well. Nothing significant though, not like the pics I've seen of the Teins. And I have the '04 Z springs.
Drew
2003 G35 Sedan 6MT / Black / Graphite / Prem / Aero
Old Aug 6, 2004 | 03:50 PM
RacerX's Avatar
Hey Gsedan35,
Your profile mentions modded spring seats. Can you explain this? Thanks.
04 G35s 6MT BS Aero Kit/Nav/Prem
Warning: Objects in Mirror Are Losing!
Old Aug 6, 2004 | 06:45 PM
Gsedan35's Avatar
Sure RacerX, no one makes poly upper spring seats for these cars. I wanted some so I can try and get more road feel and kill any second order bounce from the soft spongy oem mounts. So, I created what I could with some basic material's. I used a spare set of rear lower spring seats(use's a harder rubber) that I cut down slightly. Oem front upper spring seat is pictured to the right.
For the rear, I cut down the oem upper spring seat to 1/4" thick (1" thick to start) and made a pair of hard plastic bushings to fill. Hey, they have worked exactly like I wanted them too, just a lot of work with the ole dremel.
[image]http://pics.montypics.com/Gcoupe35/2004-07-07/1089186370_rear_upper_spring_seat_mod_with_bushing s.jpg[/image
Edmund Burke
G35 6mt
Old Aug 6, 2004 | 08:19 PM
jran76's Avatar
Correct I do have the Nismo S-tune suspension, basing this off of my Z, I would say it lowers the car and additional 1/2" on top of the Z suspension. Probably 1.5" from stock G Sedan height.
My personal opinion, it is the best suspension out there. The drop is perfect, although it may be a little low for some, and it handles as well as my Z. I love it.....
Alignment was very good. I am in Singapore now and do not have the numbers in front of me, but it drove MUCH better after the alignment.
Anyone in DFW, I would highly reccomend Dallas Frame and Alignment. It is a little pricey ($170), but well worth it. They do not use a computer and they do it the old fashioned way which is ideal if you ask me. I had the dealer do my Z after the drop and it was no where near spec.
Also, becasue I am out of the country, I have no pics, I have posted some a few time, and as recently as a couple days ago in this thread: https://g35driver.com/forums/showfla...=5&part=2&vc=1
2004 6MT Sedan-- Diamond Graphite
Stoptech 13" Brake kit-- Nismo S-tune Suspension
2003 Nissan 350Z--SOLD
