Feeling Slow, Advice
Old Sep 1, 2009 | 12:01 PM
BH818's Avatar
try cleaning TB (throttle body)
and do a TB reset and ECU reset
Old Sep 1, 2009 | 03:48 PM
4DGS's Avatar
He just said his VDC was on, probably made him stop dead.
Old Sep 1, 2009 | 07:13 PM
Tollboothwilley's Avatar
You should get a grounding kit for the lag that you feel.
As for feeling slow, if you haven't reset the ECU you should. A tune will really help out.
Old Sep 1, 2009 | 08:28 PM
Mustang5L5's Avatar
Feeling slow?? Flip the "SNOW" mode on if you have an X and drive around like that for a few hours.
Then turn it off and it will feel like you gained 100HP
Old Sep 1, 2009 | 11:49 PM
NFSP G35's Avatar
? = 2B || !2B
Speedometers lag bad, I tested this with my Trans-Am, I knew exactly the speed I would hit redline in 2nd (math, etc) and watched the speedometer on a WOT run. Hit the rev limiter a full 10 MPH before I should have, it was lagging by that much. It wasn't 10 MPH off, it was dead on cruising, but in quick acceleration, a speedometer will tell you nothing.
And the G is a different car with the TCS off!
Old Sep 9, 2009 | 12:45 PM
mmead16116's Avatar
Originally Posted by Wannabe6MT
Videotape another 0-60 run.
Heres mine when i was stock.
http://www.youtube.com/user/WannabeS...19/64ihJa6_lMk
You're blinker was on...
Old Sep 9, 2009 | 02:25 PM
Wannabe6MT's Avatar
-MN G Crew-
I was merging onto the freeway.
Old Sep 9, 2009 | 03:12 PM
NjMatteSedan's Avatar
don't lie Janik you're really an old man driving with your blinkers all the time
Old Sep 9, 2009 | 03:19 PM
NFSP G35's Avatar
? = 2B || !2B
That can't be it. You would hear him yelling at himself for revving up his engine!
Old Jan 11, 2010 | 07:24 PM
mikek46's Avatar
More like 200hp...and I thought I was the only one who did that
I use snow mode on dry pavement. And I just read the following in the manual, not sure what to make of it.
Starting and driving 5-23
WARNING: Never drive on dry hard surface roads in the SNOW mode, as this will over load the powertrain and may cause a serious malfunction.
Old Jan 11, 2010 | 07:59 PM
Mustang5L5's Avatar
I've never used it on dry pavement, but sometimes when we get a storm it will be on for the weekend as i drive around on snow and slush covered roads. When the roads finally dry up and i turn it off, it feels MUCH more responsive.
Old Jan 11, 2010 | 08:01 PM
r1forever80's Avatar
If he did the runs in dallas in the past month is wasnt hot. Its been in the 20s the past wk and i dont think over 60 in the past 6 wks. If you find a dyno in dallas or track let me know. i curious also
Freeman186
Sep 6, 2023 10:07 AM
magnetism80
Feb 1, 2019 10:00 AM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
migurus
Sep 5, 2015 09:39 PM
