Rear Defogger not coming on
Old Sep 8, 2009 | 06:43 PM
ctk519's Avatar
My rear defogger is not coming on. When I put the key in and go to start the car all of the lights on the dash, including the rear defogger button, light up as they should, but when i go to turn the defogger on, the light does not come on. everyhting else on the instrument panel (ac/mode fan up/down) all those buttons work fine, the light does not come one when i press the defogger key. Why isnt this coming on?
*It does have a metra dash kit installed, but like i said everyhting else works just fine.
**The driver's side power outlet recently went out as well. Could this be a combined issue?
2004 G35 sedan
Old Sep 8, 2009 | 11:36 PM
maciejk's Avatar
same fuse prolly
Old Nov 29, 2009 | 02:53 AM
ctk519's Avatar
BUMP
Checked and replaced cig lighter fuse, fixed cig lighter, still no rear defogger.
Its getting cold!....any help! Thanks!
Old Nov 29, 2009 | 08:03 PM
TurTLe*'s Avatar
did you check all the fuses...
defroster fuse is normally on its own.
get a volt meter and go back to see if you get voltage there after you confirmed the fuse is working.
Old Nov 29, 2009 | 10:18 PM
ctk519's Avatar
I have checked the fuses and as stated replaced the cig lighter fuse. Would this fuse be under the hood instead of in that lower panel? I noticed a "mirror heater" fuse, but it was fine.
Also, currently no voltmeter on hand
Old Nov 29, 2009 | 10:59 PM
Mustang5L5's Avatar
Check the owners manual, but it's prob under the hood.
Old Nov 29, 2009 | 11:08 PM
ctk519's Avatar
Im checking right now. Thanks
Edit: There is a fuse in the fusible link (fuse F 50A) that may be out.
I will also check fuses in the IPDM E/R as well.
I think this should solve my problem. I was only looking in the fuse box in the lower panel of driver side.
Old Dec 1, 2009 | 04:25 PM
ctk519's Avatar
Ok, all fuses checked ok.
Here is what I discovered.
After toying with it for a while, i figured maybe the button is bad, since its an aftermarket metra kit. Pulled everything out and started pressing the button. Every 4th press, i could hear a click from the rear of the vehicle like the defroster was coming on, but still no light.
Any suggestions?
In the meantime, next time i need it, i'll check to see if its working after i hear teh click. It just doesn't make sense to me.
Old Dec 1, 2009 | 04:50 PM
TurTLe*'s Avatar
if you have the time, pull it out and put the OEM in and confirm.
Old Dec 1, 2009 | 05:41 PM
ctk519's Avatar
Just moved to socal and left oem in Texas...Do you know where the defroster relay is located?
Old Dec 1, 2009 | 07:00 PM
G SEDAN's Avatar
my rear defroster is out as well........but I have the JDM double din kit.
I'll check my fuses tonight.
Old Dec 6, 2009 | 08:53 PM
Prophecy's Avatar
My rear defroster is out as well. Anyone found the possible cause (e.g. fuse - if so, is it known what fuse it is exactly)? I plan on checking my fuses this coming week to trouble shoot the issue.
If not, I may have to check through the repair manual guides. I'll post back if I find something.
Old Feb 17, 2010 | 07:48 PM
ctk519's Avatar
ISSUE RESOLVED: Yes, months later, but i was motivated as i was actually going to be traveling into cold weather and was going to need it.
Pulled entire dash apart and found a small white plug that was disconnected under the steering column. Plugged it back in and everything is working great!
Guess i forgot to reconnect it when i spliced into the ignition wires for the alarm.
Other than that, I've discovered that the rear defroster generally won't go bad on its own, unless there are breaks in the grid or fuses/relays are bad.
Old Feb 17, 2010 | 08:56 PM
G SEDAN's Avatar
^i'd be willign to bet $$$ that this white plug is also unplugged on mine. can you please help me locate this plug?
All my fuses are perfect, but rear defroster still wont come on. I need to find this whtie plug!
Old Feb 18, 2010 | 10:50 PM
ctk519's Avatar
Have you ever pulled back the panel below the steering column? Its the one that has one screw right by the trunk release. Unscrew that, pull the panel down, and look right above (and towards the rear) of the trunk release, vdc, and dimmer buttons. You gotta look further back beyond those 3 plugs. I found a white plug dangling there and plugged it back in, sure enough defroster came right back on. Let me know if you have any trouble and i can try to take a picture, but just pull the panel and make sure everything is plugged in. Leaving socal and heading east on sunday, so i'll try to check back here often. Good luck
PS. you didnt mention if you checked the relays. Theyre in the IPDM next to the battery. There are also 2 rr def fuses in there. id check those first if you havent already. Are you using an aftermarket ac control? (metra). I found that if some of the ac controls are working then they should all pretty much be working, so dont waste your time reseating the connection behind the dd opening, wont do anything but waste time
