Why does everyone love OEM stuff so much???
Old Sep 11, 2009 | 03:10 PM
  #61
OCG35's Avatar
Originally Posted by dofu
I know, it really isn't that big of a physical difference until you jump 2 sizes...
Take it up into the mountains and you'll see a mix of good and bad.
why do I need mountains? I've taken it on a track (much faster and tighter corners and much faster and broader sweepers)... and mine were 2 sizes up (from 17 to 19).
The overall diameter is still the same - the total weight of wheel and tire is almost the same... so the idea that smaller heavier wheels are better (in the context of this subject) - simply isn’t true.
Old Sep 11, 2009 | 03:11 PM
  #62
Jeff92se's Avatar
Red Card Crew
I might agree if you were talking about two wheels of weight and one was 17" and the other 19". But we are talking about ~6-7 lbs of unsprung weight per wheel for the forged 19 and ~8lbs for the forged 18. WAY too much weight gain for a spinning wheel to make your case.
Old Sep 11, 2009 | 03:14 PM
  #63
OCG35's Avatar
.what post are you referencing Jeff?... I'm not following your point
Old Sep 11, 2009 | 03:15 PM
  #64
dofu's Avatar
20 Year Member
From what I remember, the tires don't matter here since the flex or something, not really sure why... look for articles yourself, it should be all over google.
But it all has more to do with gear ratios, engine speed and wheel rotation...
Don't get me wrong, I'm not saying a larger diameter wheel is always a bad thing, the thinner sidewall you're probably installing on the larger wheel is going to give less flex, giving you better response, while also being less affected by slightly bigger road bumps
Old Sep 11, 2009 | 03:21 PM
  #65
OCG35's Avatar
^^^ you're bringing things to the discussion that have nothing to do with the subject.
I mean - tire pressure (regardless of size) will affect rolling resistance and therefore acceleration too (as will a wider tire)... but this is not the point.
The entire discussion is moot anyway because the vast majority of bigger wheels in fact are heavier than smaller... most people don’t bother to find light-weight bigger wheels. In those cases it’s the weight more than the size that is killing their acceleration (but I think most don’t care).
Old Sep 11, 2009 | 03:23 PM
  #66
Jeff92se's Avatar
Red Card Crew
Larger diameter tires on a vehicle will result in the engine turning
slower, as a result of the tire's larger circumference
Tires do matter!
If anything the weight of the TIRE will matter the MOST because it's stuck on the end of the rotating mass in question.
I don't know how many times I've mentioned the looney reason Nissan/Infiniti chooses to use the heavy cast wheels with the lighter michelin pilots while putting the anchor heavy re050s on their expensive forged wheels. Stupid
Old Sep 11, 2009 | 03:31 PM
  #67
dofu's Avatar
20 Year Member
So how does gearing, and engine speed not matter when it's all affected by the rotation of larger wheels?
OK, yea, I guess tires do matter.
Old Sep 11, 2009 | 03:32 PM
  #68
OCG35's Avatar
the shorter sidewall of the tire on a larger rim makes them less heavy than perceived... the 19" wheel/tire combo I have overall is lighter than the wheel/tire combo on my 17" OEM... (some same size tires are lighter than others too).
The weight difference between tires with the same OD (on different size rims) isn’t enough to show much difference... most people wouldn’t feel it and in many cases, 1/4 ET wouldn’t show it.
Old Sep 11, 2009 | 03:33 PM
  #69
Jeff92se's Avatar
Red Card Crew
so how does gearing, and engine speed not matter when it's all affected by the rotation of larger wheels?
affected by larger tires, tires, tires, tires.
Old Sep 11, 2009 | 03:35 PM
  #70
OCG35's Avatar
I was reffering to these parts of your post:
*the tires don't matter here since the flex or something
while also being less affected by slightly bigger road bumps*
Old Sep 11, 2009 | 03:37 PM
  #71
dofu's Avatar
20 Year Member
Either way, why is this kid proud of owning POS, way overpriced ADR aka Sterns? Those things were only good as a foot rest under my desk when I used to work there...
Old Sep 11, 2009 | 03:39 PM
  #72
Jeff92se's Avatar
Red Card Crew
Wheel weight / tire weight / overal tire diameter / are not all tied together in the context that you are dicussing.
We are discussing wheel weight vs size only. There is no gearing in this context because there are no tires or tires sizes being discussed (the thing that would determine the final diameter and the resulting final drive gear ratio)
Old Sep 11, 2009 | 03:40 PM
  #73
dofu's Avatar
20 Year Member
Ah. It's been a while... it now takes a minute for me to remember what's correct and what isn't... but when I was talking about the thinner sidewall, I was talking about the benefits of a larger wheel...
Old Sep 11, 2009 | 03:42 PM
  #74
dofu's Avatar
20 Year Member
I'm trying to think back to physics here... so say gearing and engine speed is out of the question, the wheel is still rotating unsprung mass... I just can't remember the rest right now...
Damn this thread... this is bugging me, now I have to ask...
Old Sep 11, 2009 | 03:46 PM
  #75
OCG35's Avatar
this thread has gone so far OT - I had to look at the title to remember wtf it was about
