Anyone have pics of the blue sedan with flared rear fenders?
From my current offset, 9.5 +34, I'll need 25mm to fit a 10.5 +22. As for tire size, I'm currently running 265/35, and I'll run 295/30 if I do go with this option. The tire will extend an extra 15-20mm, depending on how a 295/30 looks on a 10.5 (assuming no stretch, beefy). It might be perfect, but an extra 35-38 would be a better option since it might give me the option to run 305s.
I have 8.5 +35 and with 0 camber they are perfectly flush with OEM fenders... minor flare adds 25mm... I'm not sure how some of you guys are running wider wheels with more aggressive offsets - do you have a lot of neg camber? with the fender flare I put 25mm spacers on and it sits flush with very little camber - there is no way I could fit 10.5 +22 that’s 38mm farther than OEM fender line
I need 8.5 +15 or 9 +20 in front and 10 +30 in rear for perfect fitment (I can’t find those wheels from a G)....
Ultimately, the best option would be to have the wheels available to trial and error fit during the flare process - it would be a huge pita, but about the only way to know what wheels and/or how much flare... Otherwise, custom offset wheels are needed - I'll never find used wheels to fit my setup
I drove ttrank's car solo
Received 1,486 Likes
on
Brodys_GCoupe
11-07-2015 08:06 PM
st33zygill
07-29-2015 10:05 PM
RAVSPEC
Wheels & Tires-Vendor
07-16-2015 01:58 AM
