Rear Doors Creaking TSB
Old Oct 23, 2009 | 03:44 PM
thescreensavers's Avatar
Mr.202?
Rear Doors Creaking TSB DIY-able?
Well so I went to my local dealer to get this fixed. They wanted me to accept that I might need to pay a 120 buck diagnostics fee, which I denied since I have a freaking TSB which means Infiniti/Nissan recognize the problem and should fix it free of charge( I have Infiniti Elite Warranty). But they wanted me to accept to pay a fee still.. so I went to the parts department and got the bolts for free. The guys at the parts department are cool. second thing they have given to me for free. (first drain plug)
So now I got these four bolts, Is there a DIY or some info around that I could do this my self? I found https://g35driver.com/forums/body-in...l-removal.html but thats for a coupe, and more or less just removing the door if its the same with the sedan but I don't know what to do after.
GW-80 to GW-83 in the Service manual- it seems as soon as I take off the metal cover it should be visible..
any input? What exactly is this piece doing? Holding the window? I will do one screw at a time, but I don't know what might happen.
Thanks
Old Oct 23, 2009 | 09:55 PM
bkd's Avatar
bkd
The bolts do hold the window, and if you do one at a time you won't have any problems. Remove the door panel. Leave the key in so you can raise/lower the window. With the window about halfway down you will be able to see the bolts through the metal frame of the door like your picture shows. I didn't bother peeling back the clear plastic moisture barrier, I just used my nutdriver to poke a hole where I needed it. The squeeking came back after I changed the bolts the first time, so the second time I used blue locktite. After that, I haven't had any squeaks for over a year. I used a piece of duct tape to cover the holes I punched in the vapor barrier. You could always peel back the vapor barrier but the black goo that holds it on is really messy and it's a pain to deal with.
Old Oct 23, 2009 | 10:46 PM
Mr.202?
^^ I did not know about this moister barrier. Thanks for the Locktite thing, ill go pick some up tomorrow.
So this barrier will be between the metal panel and the guts to the window? Its just a plastic thing? Thick or thin?
Thanks for the help
Old Oct 24, 2009 | 07:42 AM
bkd's Avatar
bkd
It's a sheet of clear plastic, thinner than a shower curtain, but thicker than saran wrap, it's transparent enough that you can see through it. It's about the same as visqueen or plastic sheeting used in painting or home construction.
Old Oct 24, 2009 | 09:27 PM
Mr.202?
^^ Thanks for the help!
I have made a DIY VID + PICS
https://g35driver.com/forums/interio...ml#post4652973
rezendvous420
May 31, 2020 01:26 PM
tiguy99
Mar 1, 2016 11:42 AM
iknowitsfast
Aug 12, 2015 02:08 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
