Engine undercover
I made an alum. belly pan for my vw because the plastic one would get torn off in the deep snow over winter.
I used 1/8" alum. was super easy to work with and super durable. Because it was rigid, I only used 4 fasteners on it too. Dzues fasteners would be even more the sweet. We have tons of salt hear and I saw zero corrosion in 4 winters.
I'm probably gonna go through Seibon and get a CF piece, about 1/8 to 1/4" thick, basically it's a fiberglass piece with some carbon laid on it and it will be cut to shape and drilled into the bottom of the bumper and attach to all factory points...I'll probably leave a window for draining the oil and removing the filter so I don't have to worry about removing it.
I've seen the durability and it's amazing. From what I was told you could stand on the bumper and it will support the weight.
Just another idea/option if you're seeking to get something replaced. I personally don't like the plastic one because it's too thin and mine got ripped to pieces so I had to take it off.
I plan to have something done, but not aluminum. My reasoning is to keep my front bumper (karookie) more stable when going up driveways to prevent cracking and whatnot.
Won't be for a while lol, not really a priority of mine. I can't take the credit though, that goes to Alex from Battle Version. It wouldn't fit my theme, but he suggested the CF piece extending out a little on the front sides of the bumper to give it a more aggressive look.
Freeman186
09-06-2023 10:07 AM
AuAltima3.5
09-13-2015 10:53 AM
