GI: G35x Aluminum Undertray
Old Oct 29, 2009 | 02:16 AM
G SEDAN's Avatar
Im keeping a close eye on this one!
Old Oct 29, 2009 | 11:10 AM
ccc123pm's Avatar
X
it should realistically take about 4-5 hours to draw, program, fab one of these. The hardest thing I think would be to ensure that the holes line up, and couldnt you locate them based on the stock piece.
Old Oct 29, 2009 | 12:39 PM
NismoGirl2001's Avatar
A test fit of the 350z piece has already been done on my car a couple weeks ago. The mounting points in the rear are completely different and the door for the oil change has to be reworked b.c of the difference in location of the filter on the X.
Old Oct 29, 2009 | 01:12 PM
The Stimulation's Avatar
I stated something in another thread, can't remember which one so I'll just retype. There is a route you can go, that would also add stability to the bumper, especially if you have an aftermarket one.
Contact Seibon and they can get you a fiberglassed piece with carbon on it (not sure if it's an overlay or what, but it's about 1/8" - 1/4" thick and you can bend it like no other. You can cut out a window for it and have a larger piece for that window so it can be easily removed.
I don't think it would cost too much and it would be an alternative...it'll just require some work to have it shaped properly.
Old Oct 29, 2009 | 03:20 PM
ttrank's Avatar
Grocery getter
+1, that isn't that much for what it is. I'll be running the RareJDM one when its released.
Have Darren, Zach or anyone given you an idea when it will be ready? I was waiting for that one too but have not heard anything in quite a while.
Old Oct 29, 2009 | 03:27 PM
AARONHL's Avatar
Make one for the RWD!!!!!!
Old Oct 29, 2009 | 03:37 PM
ttrank's Avatar
Grocery getter
It's made now...
Did you look at those links before you posted?
Old Oct 29, 2009 | 05:34 PM
azt108's Avatar
I'm manufacturing cardboard undercovers. Effectively soaks up any oil leakage from your head gasket and oil pan spacers. $25 + shipping. PM me.
Old Oct 29, 2009 | 05:36 PM
AARONHL's Avatar
Yes, the first one. I just read it was for the 350Z so I posted here.
Old Oct 29, 2009 | 07:12 PM
Mustang5L5's Avatar
Originally Posted by NismoGirl2001
IFor those of you who do your own oil changes it will be less of a PITA b.c you will not have to remove the whole thing anymore.
I actually prefer to take the cover off. It's a way to inspect things underneath and see if anything needs attention. Cover still needs to be removed to replace the belt, and change the front diff fluid. And it isn't that hard to remove with a cordless and 10mm nutdriver tip.
Like i said, looks great, but can't justify nearly $300 on it when i'd prob take it off for oil changes anyway.
Old Oct 29, 2009 | 08:24 PM
snotf's Avatar
although it does look great, i really dont see why the fuss... and not to **** all over your thread but aluminum? really? why such a soft metal? anyways i think if you really care that much about removal of that skid plate you should just relocate the oil filter or remove the whole skid plate altogether... if you really whack something, plastic is going to offer only slightly less protection than your 300.00 cnc'd shiny seram wrap jobby
Old Oct 30, 2009 | 12:25 PM
SLVR JDM's Avatar
Man, high cost and very little benefit.
Old Dec 10, 2009 | 03:13 PM
ccc123pm's Avatar
X
did this ever get off the ground?
Old Dec 10, 2009 | 05:00 PM
Nope.
Old Dec 10, 2009 | 06:13 PM
  #30
TurTLe*'s Avatar
after seeing my tray the other day... i want a metal one...
1. NismoGirl2001
2.TURTLE*
3.
4.
5.
