What mod to do FIRST?
![Wink](https://g35driver.com/forums/images/icons/icon12.gif)
a bit different. ![Wink](https://g35driver.com/forums/images/smilies/wink.gif)
only budgetted for on mod right now. ($400 max). Which to do? Want a bit more growl/touch deeper exhaust note at daily driver speeds (not WOT) and performance grunt
HFC/Test Pipes?
Motordyne XYZ
HKS Rear Section
already have z-tube/KN drop in and plenum spacer to come.
HFC/Test Pipes?
Motordyne XYZ
HKS Rear Section
Test pipes, no....it's just going to make it sound raspier. HKS rear, will sound nice, buuuut I dunno, for almost 400 I'd look into something else. I'll be getting a new muffler next week (long as its in stock) and I'll post sound clips if you're wanting to wait till then.
I truly think exhaust is the way to go. If you want a cheap solution, take out the muffler and replace it with a straight pipe and add a tip. I did that and it cost me $60 and it was nice and deep, louder than HKS and I got many compliments. I had it paired with a coupe midpipe as well. I'd recommend a resonated tip, it's slightly less loud, but it eliminates rasp at WOT.
Yea HKS sounds really good, but for the money, mehh
