Vibration undernath car on passenger side of vehicle
Old Oct 29, 2009 | 07:04 PM
cq310's Avatar
Hey Guys.
A couple of days ago i started noticing a vibration coming from underneath the passenger side of the vehicle. You could hardly notice at all from outside, but once inside it was easily heard/felt. I jacked it up to see if i could find anything, and it seems to be the fuel line vibrating that's causing it.
My first thought is that my fuel pump is going bad ( car is at 94k miles atm), but I'm wondering if anyone has any other ideas of what might be causing the problem. I'll appreciate any help you guys give me
Old Oct 29, 2009 | 08:47 PM
AARONHL's Avatar
Most likely it will not be your fuel pump. Is it a thumping, or just overall roughness? When does it happen and where can you feel it? Going over bumps? Certain speeds? Just try to be more specific.
How is the wheel balanced? Is the fuel line actually moving when you touch it?
Old Oct 29, 2009 | 08:58 PM
cq310's Avatar
Wheel balance is fine, while driving the vibration isnt an issue. I can actually feel the fuel line shaking when i touch it. All the way back from the fuel tank to the engine.
When I start the car it doesn't do it, but after driving for a couple of minutes I start to feel it. I really only feel it when i'm stopped afterwards. As I'm driving you would only notice it if your sitting on the passgenger side front/rear seat at your feet.
Old Oct 29, 2009 | 09:17 PM
AARONHL's Avatar
Is it secured in it's mounting "clip"?
Old Oct 29, 2009 | 09:45 PM
cq310's Avatar
Yea, It looks like the all the clips are on there throughout the line.
Old Oct 29, 2009 | 09:46 PM
AARONHL's Avatar
Strange, how loud is the noise?
Old Oct 29, 2009 | 10:15 PM
cq310's Avatar
Outside you dont notice it all, but its loud enough inside the car where as soon as you open the door you can hear it.
I've been having no problems starting the car, accelarating, or stalling while driving. So that makes me think its not the fuel pump like you said, but I'm out of ideas as far as what else could be causing the fuel line vibrate as much it is.
Old Oct 30, 2009 | 12:05 AM
Gsedan6mt's Avatar
its a bad fuel damper, go to your local dealer part# 22675-am60b
Old Nov 4, 2009 | 10:55 PM
cq310's Avatar
Thanks, for all your help guys. I went ahead and ordered the fuel damper... was planning on taking it to my mechanic to get it installed, but started flipping through the maintenance manual and it looks like it sits on top of the engine with the hose running down to the fuel line...is that correct? and does anyone have any tips or anything i should watch out for when replacing the part?
Old Nov 4, 2009 | 10:58 PM
azt108's Avatar
Post a DIY video!
Old Nov 5, 2009 | 12:46 AM
AceG35X's Avatar
Hmm i have a vibration and rubber thumping noise coming from the front passenger wheel.. i just lowered my car on 350z/coupe springs.. so im pretty sure its a bad shock.. but it can also be a blown wheel bearing.. does the sound come from the tire/wheel? and can you hear it when ur inside the car? Also is it vibrating when ur car is parked?
Old Nov 12, 2009 | 10:30 PM
Ray Finkel's Avatar
I have this same exact noise. My wife's complaining about it is far more annoying but whatever.... The car was 500 miles past due for an oil change and I was dreading that I let it run low and what I was hearing was the valvetrain or something. I changed the oil and didnt burn much at all, thank God.
After doing the oil change I started the car and let it run for awhile on jack stands. The noise reminds me of hearing from a long distance a semi using it's jake brake. The sound cannot be heard from anywhere other than the inside. With the stereo and AC on its not too noticeable. I finally touched the fuel line nearest the outer passenger side of the car and determined where it was coming from.
Anyway, post up how this DIY is. Thanks guys.
2004 Sedan
Old Nov 17, 2009 | 12:16 AM
blackie83's Avatar
https://g35driver.com/forums/g35-sed...r-diy-fix.html
rezendvous420
May 31, 2020 01:26 PM
mbe093
Lights
Oct 2, 2016 11:09 PM
yassy
Aug 3, 2015 12:24 AM
wylin
Lights
Jul 18, 2015 06:12 PM
