fog lamps
Old Nov 16, 2009 | 10:18 AM
boomin3's Avatar
yea i am prob going to put the hids in and see how it looks, does anyone know if you have to pull off the bumper to remove the headlamps
Old Nov 16, 2009 | 10:20 AM
boomin3's Avatar
Originally Posted by Mustang5L5
Factory HID's are 4300K as an FYI. That's usually what most OEM's are.
yea i know they are the same kalvens but different car brands have different colors, i work at a bodyshop and if we put an lexus bulb in an acura the color difference is huge
Old Nov 16, 2009 | 11:27 AM
4DGS's Avatar
Yes bumper needs to come off to remove headlights, but you don't need to remove the headlights to change the bulb. You can access the rear of the headlight through your fender wall, there's a DIY somewhere. But keep in mind, it's a tight frustrating fit.
Old Nov 16, 2009 | 11:35 AM
The Stimulation's Avatar
Factory
8k HID's (swapped bulb) and 3k HID fogs (complete HID kit)
Unfortunately I don't have evening pics. I'll see if I can take some today. There was a HUGE difference in output from the factory fogs to the HID 3k's. I'm probably going to sell my 3k bulbs down the line though and swap them for 6 or 8k's and relocate the fog lights into the bumper. Gonna mold them and run dual projectors in each vent.
Old Nov 16, 2009 | 11:43 AM
boomin3's Avatar
wow they look good wit the yellowish color. the ones i have from the rx are pure white maybe i should change the bulbs. i just dont want my fogs over powering my factory hids
Old Nov 16, 2009 | 11:58 AM
Overpower in what way? The fogs are aimed much more downward so it won't affect the low beams. Or do you mean overpowering in another way?
Old Nov 16, 2009 | 12:17 PM
MarkG's Avatar
Yellow (2500K) fogs are great on my Frontier for rain and bad weather. On the G, if I go with yellow fogs, that also means my high beams will be yellow. I've never had yellow high beams - how do they perform?
Old Nov 16, 2009 | 12:34 PM
jimmyc13's Avatar
Freaking great IMO... They are even better when you flash someone @ night .
Old Nov 16, 2009 | 12:52 PM
Sacch's Avatar
Isnt it kinda wierd how our highbeam comes from the fogs lol
Old Nov 16, 2009 | 02:08 PM
boomin3's Avatar
by overpower i mean the rx bulbs might be a greater white so u notice them more
Old Nov 16, 2009 | 02:25 PM
Ah I see. The fogs point down lower than the low beams so i don't think it would be an issue.
Old Nov 16, 2009 | 04:19 PM
Sacch's Avatar
Old Nov 16, 2009 | 04:35 PM
MarkG's Avatar
Thanks for that! I was wondering about the transition your eyes make from white HID lows to yellow halogen highs, which is a lot more of a difference than the stock halogens. I think I'll give them a try this winter.
Old Nov 16, 2009 | 04:49 PM
Sacch's Avatar
Old Nov 16, 2009 | 05:54 PM
  #30
MarkG's Avatar
Not really weird, they use dual filament bulbs.
