brake + slip + vdc = fmlwtfbbq
Old Nov 18, 2009 | 06:18 PM
bbs350z's Avatar
hey guys, i recently changed my brakes to brembos which didnt clear my front wheels so i had to put oem back on (changed only passenger side front caliper). i bled properly and now have the brake, vdc, and slip light all on. disconnected the battery, no luck, tried resetting ecu, no luck. lights go off, and pop back up. wtf, help me out guys. thanks!
Old Nov 18, 2009 | 07:06 PM
Tollboothwilley's Avatar
i think you disconnected the VDC connection. Connect the sensor up and you should be good.
Old Nov 18, 2009 | 07:11 PM
06g35meister's Avatar
Fluid levels ok? When it gets low all those go off.
Old Nov 18, 2009 | 07:13 PM
nghiars's Avatar
^^^+ 1 on posts 2 and 3
fmlwtfbbq, love it BTW
Old Nov 18, 2009 | 08:20 PM
CandlestickPark's Avatar
ill Sedan
+1 on checking your brake fluid level. My dash lights came on a few weeks agi, filled my brake fluid to "max" and they haven't come on since.
Old Nov 18, 2009 | 10:02 PM
JoeSage's Avatar
its your break fluid level
Old Nov 19, 2009 | 04:05 AM
bbs350z's Avatar
i only did my passenger front caliper.. nothing else was disconnected to my knowledge, but wouldnt hurt to check lol
it was between min and max, so should be but from what im reading i should top it off
just topped her off, ill give it a shot. thanks guys
Old Nov 19, 2009 | 12:40 PM
If the fluid is between min and max it shouldn't kick the lights.
My bet is still on the VDC sensor. Take the wheel off and double check everything.
Old Nov 19, 2009 | 03:24 PM
Kris79's Avatar
battle froggy
the abs lines might be pinched.
Old Nov 19, 2009 | 05:28 PM
bbs350z's Avatar
topped off the fluid, problem solved : )
now on startup car dips to almost zero and goes back to idle...any ideas lol?
Old Nov 19, 2009 | 05:36 PM
NjMatteSedan's Avatar
^ lol always something
Old Nov 19, 2009 | 08:30 PM
bbs350z's Avatar
tell me about it. i thin its prolly just an 02 sensor or something. lucky me i have like 8 of them lying around lol.
Old Nov 19, 2009 | 10:54 PM
G35xChicago's Avatar
car is learning ??
Old Nov 20, 2009 | 03:36 AM
bbs350z's Avatar
Originally Posted by G35xChicago
car is learning impaired??
fixed you just signed up recently to chicago z right? find me on there boostin350z, and congrats on your buy!
