so many creak sounds now
Old 11-26-2009, 01:06 PM
blownvert's Avatar
when i come to a stop now and apply my brakes. i can hear all these different creak sounds coming from under carriage. sometimes when im turning my wheel at a few miles per hour, i can hear creaks. when im driving like 5 miles a hour and then hit breaks to stop. i can hear creaks. like when gravity and car pushes forward, but breaks are stopped. thats why it creaks in the front. i still have this fluttering sound coming from front right break area. i thought monroe fixed it, but it seems like its back. if i tap and hold brakes lightly driving, i can hear this fluttering cricket sound. they shimmed down the break pad, they applied and sprayed brake noise quieter stuff. my car is over 61k miles now. seems like more and more problems are coming about now. anyone else have these issues? my suspension going?
Old 11-26-2009, 02:29 PM
Tollboothwilley's Avatar
its your compression rods
the bushings are bad...either replace with the revised bushings or the whole compression rod
i did the bushings for $40.
Old 11-26-2009, 06:43 PM
blownvert's Avatar
ive had front compression rods replaced when car was under warranty prob 20 or 30k miles ago. what bushings? how much does all this cost? The compression rods were replaced because when i went over a speed bump slowly, it would creak. It doesnt do that right now.
Old 11-27-2009, 01:08 AM
it doesn't sound the same as the compression rod issue you had before? Creaking is a sound I've only heard with the compression rods.
suspension/brakes would cause clunking,squealing or squeaking most of the time.
Old 11-27-2009, 02:30 AM
blownvert's Avatar
when i first start the car and drive and tap brakes. i have squeaking at the beginning also. I have pretty much new rotors pads on front and pad, front being newer. Do you think the back is going again? it seems i have so many problems lol
Old 11-27-2009, 12:18 PM
hard to diagnose a sound over the i-net
are you sure its not the compression rods? I know people that have had issues multiple times.
Old 11-28-2009, 04:52 PM
VQ Hotness's Avatar
Get a louder exhuast
Old 11-29-2009, 09:10 PM
blownvert's Avatar
every time i hit the brake and hold it coming to a stop, i hear this noise like a chugging clicking sound sounds like from suspension.
Old 11-30-2009, 08:24 PM
olopez's Avatar
Old 12-01-2009, 10:32 PM
blownvert's Avatar
everytime i hit the break slowing down. i have this loud clicking sound
Old 12-02-2009, 06:35 AM
geew1z's Avatar
are all your lugnuts tight?
Old 12-05-2009, 09:26 AM
blownvert's Avatar
i went to monroe, they said it was swaybar links. went to infiniti was going for those, but they diagnosed something else. first said it was compression rods, but i just got those changed 30k miles ago. then they said it is the brakes. so now i have to go back to monroe and tell them to pay for the diagnostic fee from infiniti and replace my brakes because they did them originally.
Old 12-14-2009, 10:11 AM
montyz81's Avatar
68k miles and i have the creaking sound in the rear. I have a 6-MT. I have pulled the entire rear seat out to find the creak. Am I hearing that this is a compnression rod issue?
Old 12-14-2009, 05:16 PM
Mustang5L5's Avatar
Compression rods are up front. Rear creaks are different issue
Old 12-15-2009, 02:52 AM
jmonsale's Avatar
Same here I'm hearing the rear creaking with harsh roads espeacially. So what's causing that?
Quick Reply: so many creak sounds now
