Air Bag Light
Old Nov 30, 2009 | 09:01 PM
DavFlo's Avatar
Question Air Bag Light
Just recently changed the cabin air filter. Reconnected 3 separate wire harnesses --- one for the glove box light, one for the trunk lock-out, and one that I assume has something to do with the passenger side air bag. Now the air bag light keeps flashing all the time. What did I do wrong and what do I need to do to correct this? All fuses seem OK.
Old Nov 30, 2009 | 09:15 PM
Mustang5L5's Avatar
Search for the air bag reset procedure...and perform it.
Should do the trick.
Old Dec 31, 2009 | 03:45 PM
matt draudt's Avatar
what did you do to correct it?
i have the same problem
Old Dec 31, 2009 | 03:47 PM
ShanesG's Avatar
is the on on your gauge cluster blinking or the on on your climate control?
Old Dec 31, 2009 | 03:57 PM
its on the guage cluster.
Old Dec 31, 2009 | 04:03 PM
ShanesG's Avatar
with car off
turn key to on position, as soon as you see the airbag light go off, turn ign off immediately
repeat that 4 times, then start the car up, should be gone!
Old Dec 31, 2009 | 04:08 PM
ok it worked!!!!! thanks man!!!!! Do you have any idea why it would come on though?
Old Dec 31, 2009 | 04:12 PM
ShanesG's Avatar
Usually if you unplus something that has to do with any airbag sensor. But if it comes on again i'd get it checked out for sure if you're still under warranty!
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
.cakestar
Engine - Intake/Fuel
Aug 25, 2015 03:17 PM
ZacDesu
Jul 14, 2015 11:13 PM
