How big of a spacer do i need?
Old Dec 2, 2009 | 12:27 PM
highoutput's Avatar
Im going to roll the fenders, and was wondering how many mm spacer will i need to sit flush. 19 x 8.5 33mm offset on 245/40/19. thanks
Attached Thumbnails How big of a spacer do i need?-cimg0078.jpg   How big of a spacer do i need?-cimg0079.jpg
Old Dec 2, 2009 | 12:56 PM
Tollboothwilley's Avatar
Assuming you don't change your camber, i doubt you'll get more than 5mm. 10mm spacer will be close.
Old Dec 2, 2009 | 02:15 PM
4drmadness's Avatar
yup 5mm should suffice
Old Dec 2, 2009 | 02:17 PM
G SEDAN's Avatar
your fenders look like they're rolled. at least 10mm. 5 will not a noticeable difference
highoutput's Avatar
with 5mm, can i get by with the stock bolts or do i have to upgrade to longer bolts
Old Dec 2, 2009 | 02:18 PM
4drmadness's Avatar
You can get the universal 5mm spacers, which work with stock bolts.
Old Dec 2, 2009 | 02:20 PM
highoutput's Avatar
are our bolts short enough to do 10mm hubcentric spacers, or is that 15? i forgot
G SEDAN's Avatar
any sort of spacers you put on, I'd get the kit that comes with extended studs or built in studs. It's dangerous to reuse stock studs with spacers.
Old Dec 2, 2009 | 02:23 PM
highoutput's Avatar
off topic real quick, i just ordered the berk hfc for the sedan, any of you run them on your sedans? i couldnt really find anyone for testimonial purposes
highoutput's Avatar
gotcha
Old Dec 2, 2009 | 02:28 PM
4drmadness's Avatar
^ also get hubcentric rings
Old Dec 2, 2009 | 02:35 PM
CandlestickPark's Avatar
ill Sedan
Here is an idea of what 10mm spacers in the rear looks like on Coupe 19s and 245/40 tires. My camber in these pics was ~1.4 or so IIRC. Fenders rolled very flat.
10mm spacers - rear
Old Dec 2, 2009 | 02:39 PM
ill Sedan
For the fronts, if you are running 245/40 you'll only be able to run a 5mm, with a 10mm I rubbed like crazy.
Old Dec 2, 2009 | 02:41 PM
highoutput's Avatar
haha, couldnt ask for a better example, thanks candlestickpark
Old Dec 2, 2009 | 02:43 PM
highoutput's Avatar
it shouldnt be a problem running 5 up front 10 in the rear with awd, that would put be at 8mm difference from front to back
