How big of a spacer do i need?
10 rear, 15 if wanna push it, could get away with some slight added negative camber, get toe bolts to fix that (they'll get you in spec up until about -3.5 to -4 degrees but you wont need to run anywhere near that. Maybe a slight pull if you want.
Fronts, you can put 10's, but probably will have to shave off some of the sidemarker bracket.
I was running Falken FK452s.
8.5 +35 is about as perfectly flush as you can get with no neg camber (my idea of flush is outside of tire flush with outside edge of wheel well)...
I would leave as is... but not more than 5mm if you must.
no.
But I have 25mm spacer that will allow them to clear
let me know if interested...
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
FS[NorEast]: New OEM G35x Compression Rods - Save!!
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
thechitoguy
Oct 1, 2015 05:25 PM
