Correct type of Coolant
Old Jan 23, 2010 | 01:21 PM
blazium's Avatar
Does anyone know the correct coolant for a 03? I recently purchased a 03 sedan and when checking the coolant (Blue) it seemed a bit low. Could I just top it off? BTW I have no idea what kind of coolant is in there now.
Thanks.
Old Jan 23, 2010 | 02:50 PM
Swivel's Avatar
Moderator
Others can chime in, but it sounds like Nissan AF you got it there. Best bet IMO is probably to grab some from the dealer and top 'er up with the same if you're not sure. Or if it's only a small top-up you could just add some distilled water.
Old Jan 23, 2010 | 03:52 PM
Dan in St Louis's Avatar
Originally Posted by blazium
(Blue)
The color of antifreeze is no longer a sure indicator of its composition.
Old Jan 23, 2010 | 05:52 PM
5150DS's Avatar
If you aren't sure, and are capable, you could fulsh and replace with new so you know what is in there. I would stick with oem or go with Zerex Asian formula (recommended by the folks at Bob is the oil guy.
Old Jan 23, 2010 | 06:34 PM
blazium's Avatar
I would rather not flush it if I dont have to..... But that seems the most reasonable solution.
Old Jan 24, 2010 | 12:13 AM
Wiseman's Avatar
flush it. get oem coolant and distilled water and make the 50/50 combo. search on here, plenty of posts regading this.
Old Jan 24, 2010 | 06:41 PM
blazium's Avatar
whats the correct oem coolant. I guess now I have another project for the weekend.
Old Jan 24, 2010 | 11:18 PM
geew1z's Avatar
I know some vehicles come with the blue coolant and its fine to mix in green. Plus alot of coolant is able to be mixed with whatever other coolant there is. It'll say on the jug.
KruZZe
Feb 27, 2023 05:04 PM
Video Share
Jan 31, 2017 04:00 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
BradMD_96
Oct 6, 2015 09:31 AM
