Car idling weird?
Old Jan 30, 2010 | 07:25 PM
NjMatteSedan's Avatar
Car idling weird?
when my car was parked i noticed my idle rpm was sitting on the first small line or dash that's after the first longer rpm line (hope that makes sense) it would move up and down the second line and the engine would feel like vibrating a little bit, the rpm was fluctuating up and down too frequently it was 20 deegrees out if that matters
Old Jan 30, 2010 | 08:11 PM
SxExCx's Avatar
Have you recently installed anything new? Did it settle down once the car warmed up?
Old Jan 30, 2010 | 08:41 PM
Nothing new, I've got my z tube since the summer with no issues. Maybe is cuz I didn't warm up my car? When the temperature was normal it was still doin it, I really should warm up my car instead of get in and drive in freezing temperature. My oil change is not due yet either
Old Jan 30, 2010 | 08:44 PM
PAIXAO's Avatar
I get in and drive my car all the time when it's this cold. IMO that's the best way to warm it up as it circulates the oil to parts of the engine that need it most when it's cold.
Try checking your vacuum hoses, clean your MAF, make sure everything is tight and check your oil level.
Old Jan 30, 2010 | 09:08 PM
NFSP G35's Avatar
? = 2B || !2B
Is it still doing it?
Old Jan 30, 2010 | 09:18 PM
SxExCx's Avatar
The reason I asked if you had installed anything new is because vacuum leaks are common if everything isnt installed to the correct specs.
Old Jan 30, 2010 | 09:53 PM
AARONHL's Avatar
Clean your throttle body...AND do the "re-learn procedure".
Old Jan 30, 2010 | 10:01 PM
Is wayy too cold to go out and check lol hopefully tomorrow it'l be fine, just thought it was weird how the rpm was going up and down by itself and u could hear it if it continues I'll have to have some1 have a look at it
Old Jan 31, 2010 | 12:53 AM
AARONHL's Avatar
I hear ya!
Old Jan 31, 2010 | 01:07 AM
azt108's Avatar
That happens to me too, its normal. I think its fine as this is the computer adjusting the idle to warm the car up. Once its warm it should be below the first 'big line'.
Old Jan 31, 2010 | 07:05 PM
^ once the car is warm is still doing it going up and down, but when the car is moving i don't feel anything weird
Old Jan 31, 2010 | 08:44 PM
iTzTeddy's Avatar
I have the same problem, I thought it was normal but then its really good here in MA too.
Old Jan 31, 2010 | 08:50 PM
^i would think it was normal too if it had always done that but it just started doing it yesterday
Old Feb 1, 2010 | 01:31 AM
sick4dr's Avatar
when this happens its generally a vaccum leak or your idle control valve may be sticking
Old Feb 1, 2010 | 03:38 AM
^thanks i'll look into that, lol i find it ironic that you're helping me and you have 3 posts and i have 2500+ haha, but that may very well be the issue
