No Cobb For Sedans??
Old Feb 4, 2010 | 06:36 PM
813G-WHiP's Avatar
I was looking into purchasing a Cobb Access Port for my 05 sedan and I was asking the vendor what stage I should go with and I was told that Cobb says the software doesn't work for the sedans.. Is this true? Is there any other tuners that do work?
Old Feb 4, 2010 | 07:23 PM
nghiars's Avatar
why would it matter if its a sedan or not.. the ecu should be the same.
Old Feb 4, 2010 | 07:38 PM
Blue Dream's Avatar
I drove ttrank's car solo
Fvck the Cobb, Osiris is the way to go if you're looking for a good tune.
Check here for the closest retailer/installer to you: https://g35driver.com/forums/tuner-d...directory.html
Check post #8 for Florida locations.
Old Feb 4, 2010 | 08:31 PM
813G-WHiP's Avatar
what is osiris? i keep seeing stuff mentioned about it
Old Feb 4, 2010 | 08:54 PM
azt108's Avatar
Its the lord of the dead.
Old Feb 4, 2010 | 10:27 PM
Tollboothwilley's Avatar
www.uprev.com
read up
Old Feb 4, 2010 | 11:06 PM
HwyDrftr's Avatar
It does support the sedans, not sure where the vendor got that Idea from, really osiris tuner and the cobb do the exact same thing, they are able to flash the ECU with the same settings. The tuning software for the cobb only came out last year, until then most people ran the "Stage" tunes which were pretty hit or miss, because of this the cobb got a bit of a bad rep. What I like about the cobb is that it has real time monitoring, you can display several different things like a/f, Fuel Economy, 0-60 etc. It also will let you adjust idle and timing in real time. Another good thing about the cobb is people are selling them cheap because they don't know what they have.
Old Feb 5, 2010 | 12:06 AM
HwyDrftr's Avatar
Just noticed they dropped the price for the cobb this week http://www.cobbforums.com/forums/sho...rice-Reduction
Old Feb 5, 2010 | 12:08 AM
azt108's Avatar
Can someone explain to me why it costs $700 to flash an ECU? You can flash your own motherboard on your PC for free. In fact you can flash anything given there is an application written to recode the hardware. Maybe I'm totally misunderstanding the concept of tuning, but from what I understand things can be flashed and reprogrammed fairly easily. Configurations could also be available online for free along with tuning recommendations for the enthusiast. Someone shed some light on this.
Old Feb 5, 2010 | 12:16 AM
DG Steelo's Avatar
Good lucc Decodin that ish.... The Maps and Programs have been decoded by these companies already... Not an easy task....
Old Feb 5, 2010 | 12:18 AM
azt108's Avatar
Well just like they crack windows OS and other applications that get pirated, I still don't understand why it can't be done with our cars and the application be downloaded and run via a laptop...
Old Feb 5, 2010 | 12:33 AM
813G-WHiP's Avatar
it can but who wants to take the risk of messing up your ECU?
Old Feb 5, 2010 | 12:37 AM
HwyDrftr's Avatar
lol, here ya go nub
http://www.romraider.com/
http://forums.openecu.org/index.php
http://www.evc.de/en/download/down_winols.asp
Old Feb 5, 2010 | 02:47 PM
blazeplacid's Avatar
its really no different than say...adding a CAI or a plenum spacer, in terms or risk.
if you know computers as well as you know cars, its easy
just as easy as you can spot a 10mm bolt, some people can spot an open loop hole in programs
Old Feb 5, 2010 | 10:33 PM
813G-WHiP's Avatar
very true but there are those people that THINK they know what they are doing and may know how to work their way through a computer but no **** about cars and how they run.. lol
