6AT Gear shift
Old Feb 5, 2010 | 09:31 PM
jmcohen23's Avatar
6AT Gear shift
Stupid question here (and I'm fully expecting to be laughed at):
I just noticed on my 2005 6AT that there is a + and - sign next to the gear shift. I noticed it when I accidently hit the gear shift (while in D) and it moved to the right.
What does this do? Does this turn it into a manual, or simply like a D1 and D2? If so, what are some of the dos and donts with this shift ****?
thanks....
Old Feb 5, 2010 | 09:34 PM
Mustang5L5's Avatar
Yes. Slide it left and it turns it into manual mode. What gear you are in is displayed in the gauge cluster.
Basically when you upshift, don't let off the gas like a true manual. The car will also rev-match your downshifts to a point. Just play around with it and you'll see how it works. Not much you can damage here..just don't drop it 3 gears at a time and hit the rev limiter.
I usually use 3000RPM as my upshift point and 2000RPM as my downshift point. Not exactly the same as a true manual, but makes the car a little more fun to drive on good roads
EDIT: BTW, you have a 5-spd automatic...aka 5AT. Not a 6AT
KBurn's Avatar
its just like a manual mode. You can choose when to shift without having a clutch
Old Feb 5, 2010 | 09:38 PM
4DGS's Avatar
wikipedia tiptronic or steptronic.
/thread
Old Feb 5, 2010 | 09:39 PM
jlo0109's Avatar
hey bro, not try to **** you but, you have a 5AT not a 6AT. 6 is only available for MT.
Old Feb 5, 2010 | 09:41 PM
4DGS's Avatar
^already been mentioned
/thread x2
Old Feb 6, 2010 | 06:10 AM
jimmyc13's Avatar
Wow...
Old Feb 6, 2010 | 11:28 AM
NFSP G35's Avatar
? = 2B || !2B
Originally Posted by Mustang5L5
...Not much you can damage here..just don't drop it 3 gears at a time and hit the rev limiter.
I don't think you can. Mine just ignores me if I tell it to downshift too soon.
Ok Blain... go ahead, you know you want to....
Old Feb 6, 2010 | 11:30 AM
jmcohen23's Avatar
thanks Mustang5L5, appreciate it. perhaps I'll give it a whirl in this blizzard....
Old Feb 6, 2010 | 11:38 AM
Mustang5L5's Avatar
Hmm...now i gotta go try it.
Old Feb 6, 2010 | 11:40 AM
NFSP G35's Avatar
? = 2B || !2B
^Keep in mind though that mine is a first gen 03 with the old shift logic.
Old Feb 6, 2010 | 12:40 PM
4DGS's Avatar
Want to what?
Old Feb 6, 2010 | 12:41 PM
NFSP G35's Avatar
? = 2B || !2B
Originally Posted by 4DGS
Want to what?
This ----> "/thread"
Old Feb 6, 2010 | 07:33 PM
Mustang5L5's Avatar
Well, i tried it. Apparently on the 05/06's...you can.
I dropped 3 gears at once and banged he rev limiter. Poor car
So needless to say, don't anyone ever do that.
Old Feb 6, 2010 | 10:12 PM
NFSP G35's Avatar
? = 2B || !2B
^Woah. Sorry about that man. They must have really changed the shift logic a lot! Mine will only let me bounce off the rev limiter if I leave it in a gear while accelerating. But once I shift to the next gear, it won't let me go back down until I'm slow enough. I bet that changed in 04.5 like all the other transmission stuff.
