Side Marker Blinker mod
Old Sep 3, 2004 | 02:57 PM
twothdr's Avatar
Has anyone done the side marker mod on a sedan? Did you do it from the engine bay or jack up the car and removed the wheel?
Thanks,
Jay
Old Sep 3, 2004 | 04:10 PM
mrjimmy55's Avatar
Re: Side Marker Blinker mod
Jacked up the car and removed the wheel.
2003.5 Sedan 6MT Silver on Graphite
Premium | Aero | Sport | Tints
Old Sep 3, 2004 | 04:14 PM
marvinclt's Avatar
Yes, its super easy. Just make sure you don't detroy the tabs when you remove the wheel liner.
GL.
Old Sep 3, 2004 | 07:55 PM
Noremac's Avatar
<hr></blockquote>
Neither. I just turned the wheel hard to the opposite extreme, loosened the front part of the fender plastic, and did it all with the car on the ground. Sure, it would have been easier to get access with the wheel removed, but that step requires another set of effort.
<font color=blue>'04 G35S 5AT, Black Obsidian/Willow, Prem/Nav/Sat</font color=blue>
Old Sep 3, 2004 | 09:31 PM
fnt's Avatar
fnt
<hr></blockquote>
Me too. I wasn't up for removing the wheels, so I did the same as Noremac. The working space was a little tight and it was a bit difficult to get the wire taps in place, but it worked out OK.
Old Sep 4, 2004 | 12:36 AM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
I've done two cars, one with the wheel off and the other with the wheel on.
the wheel off is much smoother and easier since you have more room to work with. I did one side at a time, so just used the supplied car jack to get the car up. the extra space allowed me to re-tape all the wires and make it look like a clean install. Also gave me the opportunity to check my front brake pads and give my wheel a better cleaning.
The other car had aftermarket wheels I could not remove (no thin walled 7/8" socket), so I had no choice.
I recommend the wheel off method.
Golden Gate G35 Club
Old Sep 4, 2004 | 07:16 AM
twothdr's Avatar
Everyone tap into the green/yellow striped wire?
Old Sep 4, 2004 | 08:37 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
Yep that's the right wire.
I did mine with the wheels off & painted the calipers at the same time.
This mod is great. It should come this way from the factory.
I like the added feature that my marker flashes when I lock the car now (horn disabled).
<font color=blue>04 Silverstone G35, 5AT, Prem, Aero
ES100 225/45-18 front 245/40-18 rear
HKS & Y-pipe, Z-tube, Eibach, 35%Tints</font color=blue>
Old Sep 4, 2004 | 11:30 AM
Noremac's Avatar
If you're going to take the wheels off, please use jack stands and wheel chocks!!! I would never get under the car and rotors with only the emergency jack holding it.
Old Sep 4, 2004 | 12:53 PM
InTgr8r's Avatar
Noremac
Did you really mean to reply to me.
I didn't say anything about getting under a car with an emerg jack!
Old Sep 4, 2004 | 04:05 PM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
noremac....thanks for the heads up. all my other work I do with jack stands.
tapping into the wires takes just about as much time as changing a flat, and you wouldn't use jack stands to change a flat.
Old Sep 4, 2004 | 05:05 PM
Noremac's Avatar
<hr></blockquote>
No. Sorry. I just hit reply on the last message listed.
I didn't mean to preach. But my neighbor two doors down is lucky to only have a nasty permanent scar on his forearm as testimony to Murphy's law when his car wobbled off the emergency jack and rotor met flesh. YMMV.
Old Sep 5, 2004 | 03:05 AM
chenga's Avatar
I did it from the engine bay. I removed the intake box's resonator while I was at it since you need to take the airbox out to get to the area.
The passenger side is easier and I just stuck the wire extension through the hole from the side marker area into the engine bay, grabbed the wire and cut it to the length I needed.
No need to remove the wheels or the wheel liner. If you want to change your intake, do this mod along with it.
Old Sep 6, 2004 | 08:09 AM
Streaker's Avatar
I hate to sound like a dummy but I have no idea what the side marker mod is. I just got my G-35 last week.
Streaker in GA
Old Sep 7, 2004 | 07:15 AM
InTgr8r's Avatar
With a minor wiring change the side marker lights can be made to work with your turn signals.
I think this a great saftey enhancement, the car in the next lane will now see your signal.
