Oh man, VDC/SLIP/Speedo/Tach/Transmission and other electronic issues.
Old Feb 6, 2010 | 03:38 AM
dmitriylm's Avatar
I've had a bit of a frustrating day. I drove my car this morning just fine and later in the day when I started the car I noticed rough gear changing when going into drive or reverse. I then noticed that the VDC and SLIP lights were illuminated and I was really hoping that this was a low brake fluid issue but the fluid levels were fine. I started driving the car and the transmission was shifting gears with noticeable roughness, particularly the 1-2 and 2-3 shifts. Sometime soon the service engine light illuminated and I noticed the speedometer was reading zero. I decided to drive the car to the dealership and noticed on the highway that the transmission was rather busy, continuously up/down shifting and the tachometer was bouncing all over the place, not even seeming to be relative to actual engine speed. At some point on the freeway the transmission just allowed the engine to rev as if i was slipping and then power would come back and cut out. I took the next exit and by the time I was off I was pretty much limping along at 5mph. I would just rev without moving at every stop and by switching from drive, to manual, to neutral power would eventually come back for a short bit and then slip again (engine hit max rev's with ease). I noticed at the same time that when putting the car into manumatic shifting, the dash cluster did not register the change from D to M. My emergency blinkers were all over the place as well, the timing between blinks wasn't even and sometimes they would stay on longer than normal between blinks. I wasn't even sure if they were visible on the outside. I ended up leaving the car in a parking lot until I can get to it tomorrow. Does anyone have any ideas? I've read a bunch of threads related to slip/vdc but none seem to have the transmission shifting and slipping issues.
Old Feb 6, 2010 | 07:12 AM
Blue Dream's Avatar
I drove ttrank's car solo
It sounds like a massive electrical issue. Probably need to go to a shop.
Old Feb 6, 2010 | 08:58 AM
bluemax189's Avatar
i agree with blue dream. tow it to a shop. Good job on just leaving it before it gets real bad
Old Feb 6, 2010 | 11:41 AM
Dacket84's Avatar
That sound like a very stressful time, sorry to hear. I would get it to a Nissan/Infiniti stealership to fix it. Somebody who knows these cars, rather than some random shop. Good luck with it.
Old Feb 6, 2010 | 11:50 AM
dmitriylm's Avatar
Yeah, I've never seen a situation where even the blinkers aren't functioning correctly. I'm heading out to get the car and tow it to a shop. Hopefully it doesn't turn out to be something horribly expensive.
Old Feb 6, 2010 | 12:01 PM
goodtwogo's Avatar
Make sure you haven't lost your tranny fluid.
Old Feb 7, 2010 | 10:45 PM
thatshortkid's Avatar
Um it could just be me thinking this but somehow I doubt that is gonna be a cheap thing to fix. With that many issues all happening at once I am thinking its gonna be expensive. Did it just randomly start doing all this? Could something have triggered it?
Old Feb 8, 2010 | 01:46 AM
dmitriylm's Avatar
It all happened at one time and the probability of multiple components failing at the same time is relatively low. The shop I towed the vehicle to did a quick scan on Saturday and came back with something similar to "network communication error" and "speedometer module error". They will get to work on it on Monday to see if they can figure out whats wrong. I'm hoping its a single component, probably electrical, that's causing all the issues.
Old Feb 8, 2010 | 08:07 AM
SedanManBen's Avatar
Wow... I'm sorry to hear about that. If something similar happened to me, I'd probably start cryin'. haha
Keep us updated on what needs to be done to get your problem solved!
Old Feb 8, 2010 | 01:12 PM
dmitriylm's Avatar
They pulled the following codes:
P0500
U1000
U1001
P1212
P1574
Old Feb 8, 2010 | 01:25 PM
P0500
U1000
U1001
P1212
P1574
That somehow doesn't look fun to me. Do you have any idea what that stuff means?
Old Feb 8, 2010 | 01:30 PM
dmitriylm's Avatar
I'm actually searching around right now to see if I can find out.
Old Feb 8, 2010 | 01:34 PM
Alright let us know what you find!
Old Feb 8, 2010 | 01:46 PM
dmitriylm's Avatar
Here are the code details:
DTC: P0500
Search Bulletins/Recalls for P0500
Trouble diagnosis name: Vehicle speed sensor
Diagnosis Logic
The vehicle speed sensor is installed in the transaxle. It contains a pulse generator which provides a vehicle speed signal to the combination meter. The
combination meter then sends a signal to the ECM through CAN communication line.
DTC detecting condition:
* The almost 0 km/h (0 MPH) signal from vehicle speed sensor is sent to ECM even when vehicle is being driven.
Possible cause:
* Harness or connectors (The CAN communication line is open or shorted)
* Harness or connectors (The vehicle speed sensor circuit is open or shorted)
* Vehicle speed sensor
* Combination meter
_________
DTC: P1574
Search Bulletins/Recalls for P1574
Trouble diagnosis name: Automatic Speed Control Device (ASCD) vehicle speed sensor
Component Description
The ECM receives two vehicle speed sensor signals via CAN communication line. One is sent from combination meter, and the other is from TCM (Transmission
control module). The ECM uses these signals for ASCD control.
* ECM detects a difference between two vehicle speed signals is out of the specified range.
Possible cause:
* Harness or connectors (The CAN communication line is open or shorted.)
* Harness or connectors (The combination meter circuit is open or shorted.)
* Combination meter
* TCM
* Incorrect ASCD brake switch installation
* ECM
____________________-
DTC: P1212
Search Bulletins/Recalls for P1212
Trouble diagnosis name: ABS/TCS communication line
Description
This CAN communication line is used to control the smooth engine operation during the ABS or TCS operation. Pulse signals are exchanged between ECM and
ABS actuator and electric unit (control unit).
* ECM can not receive the information from ABS/TCS control unit continuously.
Possible cause:
* ABS actuator and electric unit (control unit)
* Dead (Weak) battery
______________
Infiniti Number U1000
Type Network - Manufacturer Controlled DTC - Manufacturer Controlled
Description
CAN communication line - signal malfunction
Cause
Wiring
*TSB
______________
U1001
Controller Area Network (CAN) communication problem
_____________
All of the codes point to a CAN malfunction.
Old Feb 8, 2010 | 01:48 PM
Wannabe6MT's Avatar
-MN G Crew-
Did you google the codes?
EDIT: Beat me too it. This is an issue you might want to have your dealer look at. This sounds pretty similar to what happened to our 04, and as i recall, it was quite expensive to fix.
