Little Shake
Old Feb 10, 2010 | 11:15 AM
kevin3751's Avatar
Little Shake
So I went to get my tires rotated and balanced, I go to drive on the highway and my car now shakes real bad. I bring it back and they fix it a little but say since I have 20" wheels instead of the stock 18"s I need some kind of ring to make it fit better for it will not shake at all. What "ring" is he talking about? A spacer? thanks for the help.
Old Feb 10, 2010 | 11:17 AM
PAIXAO's Avatar
What kind of wheels do you have?
Old Feb 10, 2010 | 11:33 AM
kevin3751's Avatar
20" Rocktstarr Rims, why would that matter though?...the guy at the shop said there is to much space and i need some kind of ring to fill the space in...
Old Feb 10, 2010 | 11:40 AM
nazc0's Avatar
2006 Vortech supercharged Sedan
hes talking about the hub centering ring thing
if they put the rims on for you they should have told you about the fact that you need one i was told i needed then for my rims and they put them on for $20
Old Feb 10, 2010 | 12:52 PM
geesahtee5's Avatar
+1.. youre gonna need it to fit our 66.1 hub..
first find out what size ur rockstarr wheels are
Old Feb 10, 2010 | 02:05 PM
SLVR JDM's Avatar
You need hubcentric rings.
Old Feb 10, 2010 | 05:22 PM
Mustang5L5's Avatar
Whoever sold/installed the rims should have told you about the rings. Usually aftermarket wheels have a larger hub area and you purchase adapter rings to fit your hub. You want this because the load of the road will transfer tothe hub and not the lugs (can snap lugs...dangerous) and because it will also center the wheel
We have a 66.1mm hub, unsure what the ID is of your wheel though. You'll have to figure that out on your own.
For your own safety, get on this quickly
Old Feb 10, 2010 | 09:20 PM
kevin3751's Avatar
Yeah, i emailed the place to get the exact size of the rim...
Old Feb 10, 2010 | 09:42 PM
azt108's Avatar
Are we allowed to post the name and address of places that provide terrible service so that we know not to go to them?
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
Fire0nic3
Sep 1, 2015 12:12 PM
miata007
Aug 17, 2015 04:36 PM
Terry_G35
Aug 4, 2015 02:38 PM
