Help with removing front bumpers then headlights change aftermarket HID/Xenon bulbs
Old Feb 10, 2010 | 02:59 PM
liweih21's Avatar
Hi, like title said, I need help with removing front bumpers then headlights change aftermarket HID/Xenon bulbs. I saw a rivet remover from the second picture here: https://g35driver.com/forums/lightin...ple-steps.html the guy is holding in his left hand - where can I buy this or is it required? to pop up the rivet and remove it.
what else I need to do? tools?
car is 2003 g35 sedan non-xenon headlight set.
also can the original xenon headlight set assembly with the original ballast plug in -non -xenon wires?
Old Feb 10, 2010 | 03:23 PM
TofuProductions's Avatar
You don't need to remove the front bumper.
This is what I do.
1) Jack up the car (whichever side you're doing first)
2) [optional] take the wheel off.
3) remove fender lining (it's like 5-6 plastic push-pin clips)
4) undo bulb cover
5) remove bulb.
Reverse steps.
Old Feb 10, 2010 | 04:49 PM
liweih21's Avatar
yeah right that is another way, but how do you guys make sure those rivets are okay since if not just cracks and breaks what kind of tools do you use to take that out.
I also need to physically take out both headlights and reseat them due to blemishes and mis-alignment that's why i need the bumper off.
Old Feb 10, 2010 | 05:10 PM
azt108's Avatar
You can heat them up with a hair dryer and lift the rivet with a flathead slightly then let your fingers do the rest of the work. However, these things break all the time just get a bunch for an auto store or infiniti.
Old Feb 10, 2010 | 10:17 PM
I use a flathead, it's not hard. just insert it into the little notch, twist the flathead screwdriver sideways and slightly up, and it'll pop right out no issues.
bTanz
Oct 15, 2015 02:31 PM
st33zygill
Jul 29, 2015 10:05 PM
EasySausage
Jul 20, 2015 03:56 PM
attarday
Jul 15, 2015 04:03 PM
