vsc light and slip light
Old Feb 6, 2011 | 02:49 PM
Mustang5L5's Avatar
Brake fluid expands very little....it's one of the reasons why it's used.
However, the water it traps will expand and contract. So...if you are noticing fluid expanding, then time to bleed your brakes
Old Feb 17, 2011 | 02:04 PM
VincenzG35's Avatar
Originally Posted by geew1z
wtf.. you dont siphon brake fluid out of the reservoir ever! You bleed the brakes using the bleeder valve on each caliper.. and even then on these cars you dont have to per the fsm, unless of course you are in danger of having the reservoir overflow when you push the piston back in.
edit: Also, I ran my pads quite low and the light doesn't come on because of that, its only because the fluid is low
yea alot of people are getting this and a burning rubber smell in the rear... i figured out yesterday that it a few things brake fluid stops the lights as previously mentioned but also my caliper was frozen (piston no longer compresses) in the rear drivers side so i had to replace it also it wore my pads out to almost nothing thank god my rotors are fine but hearing my shims sing was a terrible experience lol so if your having a burnt rubber smell with no issues noticeable check your calipers because when it freezes it doesnt work at all so ive been driving with 3 breaks
Mry
Mar 3, 2023 01:03 AM
jbmw002
Drivetrain
Aug 27, 2015 03:01 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
newg37
Jul 26, 2015 09:32 AM
