help me decide on coils!
the wheels are;
F;19x8+35 R;19x9.5+45
F; 225,35 R; 275,35
My next tires are going to be slightly thinner in the rear. I plan to go about 2.5" I'm trying to avoid buying the expensive front camber kit and only buying the rear. I might just deal with burning front tires if it's not too bad.
What about some used MDU coils off a very trusted forum member?
F; 225,35 R; 275,35
You'll need different tire sizes, those will throw your speedo off. Front is 25.2" tall and the rear is 26.6" tall. You should try 235/35, 275/30, those are both 25.5" tall.
You should just about at the top of the tire with a 2.5" drop. The top of the arch of your fender will be 25" off the ground at that height.
