What is this?
Old Mar 13, 2010 | 08:01 PM
4D05G35's Avatar
What is this?
Im not sure where to post this so I apologize if this is in the wrong spot.
So while changing my oil I found this part laying on the plastic cover under the engine and oil pan. I removed the two rear screws on the plastic cover so I could access the oil filter easier and thats when I saw this part laying on top of the plastic on the drivers side. Any help identifying this is much appreciated. I have my thoughts, but figured I would seek help from you guys.. Thanks in advance..
Old Mar 13, 2010 | 08:08 PM
NFSP G35's Avatar
? = 2B || !2B
Old Mar 13, 2010 | 08:13 PM
340tog35's Avatar
looks like a ac pulley
Old Mar 13, 2010 | 08:17 PM
NFSP G35's Avatar
? = 2B || !2B
^Yes, it does.
Old Mar 13, 2010 | 08:26 PM
4D05G35's Avatar
Uh I see pics.
Old Mar 13, 2010 | 08:28 PM
4D05G35's Avatar
A/C pulley? ill go look right now to see if I'm missing a belt
Old Mar 13, 2010 | 08:30 PM
NFSP G35's Avatar
? = 2B || !2B
Originally Posted by 4D05G35
Uh I see pics.
I didn't see the pics at first, I see them now though. Did you edit or something?
(my internet has been sketchy today, so maybe that's it)
Old Mar 13, 2010 | 09:13 PM
4D05G35's Avatar
looks to be a part of the A/C pulley, matches up perfectly. I wasnt able to dig too far into it, but it appears to be a balancing weight???. Thank you very much..here are a few more pics..
Old Mar 13, 2010 | 09:17 PM
4D05G35's Avatar
Yeah my bad. I posted the question then had to edit my post to include the pics, took about 2 min so you must have replied right after I intially posted..er or 7 min...
Old Mar 13, 2010 | 09:28 PM
NFSP G35's Avatar
? = 2B || !2B
^Yep. That's it for sure.
I'll bet you don't have A/C right now
Old Mar 13, 2010 | 10:26 PM
4D05G35's Avatar
Damn, ill have to check in the morning. So is there a belt im missing?
Old Mar 13, 2010 | 10:29 PM
NFSP G35's Avatar
? = 2B || !2B
^No, belt is still on there. That's part of the clutch mechanism that engages the compressor
Old Mar 13, 2010 | 10:38 PM
4D05G35's Avatar
ah, makes sense now.. glad its still all covered under warantee. Thank you very much. now I need to decide if underdrive pulleys are in order/worth it.
