painted my 06 calipers today
Old Mar 21, 2010 | 02:19 PM
  #31
G2FLIP4's Avatar
everything
Heres mine, obviously doesnt look that shiny cuz its in the garage right now. You can see the glossiness and reflection in the lower bar right by the hub though
Old Mar 21, 2010 | 02:24 PM
  #32
BuckeyeInMI's Avatar
Originally Posted by myGi$Gangsta
You don't need to bake em Buckeye. I used a can of brush on gloss black paint and it comes out great as long as you add clear. They cure in only like 20 mins but is better to leave the car sit overnight without driving
They've been painted and sitting around for over a week, and won't be installed for at least another couple of weeks. They're not on the car yet, so I had the luxury of taking my time. I just don't want it chipping off later and having to repaint them. From what I've seen so far, I think I'm going to put a clear coat on them. That shine is very nice.
Old Mar 21, 2010 | 02:27 PM
  #33
5150DS's Avatar
I went DupliColor black and put silver Infiniti emblems on them.
http://www.xenonmods.com/xenonmods_infiniti_items.htm
Old Mar 21, 2010 | 02:38 PM
  #34
blazeplacid's Avatar
If you like the way it looks keep it
And the duplicolor paint is really bad.
The G2 paint is worth the extra $15
Old Mar 21, 2010 | 05:09 PM
  #35
BacaraG35's Avatar
Originally Posted by Skyfox16
So i was just wondering how much you have to brush the calipers before you can paint them? it seems like its taking forever to clean these up.
The bracket on the top in the picture (shiney one) is the one i worked on for a while, did you guys make them like that before painting?
Any tips you guys have?
Use a dremel with the wire brush wheel. Try both carbide and brass wheel. Make sure you use beake cleaner before and after. Also, pull them completely apart if you can.
Old Mar 21, 2010 | 05:37 PM
  #36
TurTLe*'s Avatar
the red looks perfectly fine. Let it be till the paint fades away.
The tires on the other hand are a no go for me at the 30 sidewall. 265 is fine for 280hp. I have 265/40's
A lot of you guys are somewhat acting like SNOOBS.
They OP did some work on his car. He didn't pay anyone to do it. The quality of the work looks great. Who really cares about the color? He liked it and really thats all that matters. I like his car, next time around i would suggest he get a bigger sidewall. Even with the drop its going to look really high. Plus a bigger sidewall will cushion the ride more.
Old Mar 21, 2010 | 07:59 PM
  #37
SN00P's Avatar
CLUB MODERATOR
well i was going to get a 35 in the rear but i got a hell of a deal for all 4 tires 35 front and 30 rear ... but when i lower my car keep in mind 350z springs im going to get an extra 1" i honesty thin it should be fine in the rear on i get fenders rolled .. but when the rears ware down im deff going with 35 tires in the rear ...
Old Mar 22, 2010 | 12:37 AM
  #38
oscar_g-sedan06's Avatar
did mine 2 weeks ago also did silver not in to bright colors did the coupe 18''s also bt thinking doing rims gunmetal soon
Attached Thumbnails painted my 06 calipers today-100_4552.jpg   painted my 06 calipers today-100_4551.jpg
Old Mar 22, 2010 | 04:16 AM
  #39
TurTLe*'s Avatar
I dont think you will need to get your fenders rolled with a 30 sidewall. I i rubbed a LITTLE if i had 100lbs in the rear of my X on Z springs. which lower my AWD 1.25-1.5 inches. VS your 1.0 inch. There was a guy with a RWD who rubbed just a bit on 35 sidewall. He did a quick homemade roll and done. So your 30 should be OK. when you go to 35 sidewall you will need it then.
I completely understand when you gotta deal you make that work. Only reason why i have my 265/40 in the rear of my AWD.
Old Mar 22, 2010 | 10:52 AM
  #40
Nice work, the silver looks really good. Glad to see you painted the rotor hats too. A friend of mine has an RX-7 and he painted the rotor hats, dust shield, and calipers silver. Looks really good against his red car and black wheels. I painted everything black because I thought I already had too much silver going on with the Coupe 18's on my DG Sedan.
Old Mar 22, 2010 | 10:56 AM
  #41
welery's Avatar
Monster Truck!
Old Mar 22, 2010 | 10:58 AM
  #42
Looks like you got quite a bit of paint on the rubber boots. I'd suggest taping them off next time before painting. Probably won't cause a problem, but they could lose some of their flexibility over time. May even dry out a little quicker. Just make sure you check them every 6 months to a year (as you should normally).
BTW, they look good.
Old Mar 22, 2010 | 10:59 AM
  #43
SN00P's Avatar
CLUB MODERATOR
but im think the drop should be around 2'' .... i never have any weight in the back beside like 50 pounds of tools for work in the truck ... so i should be fine lowering it ... i have 350z tein s-techs ... and a 35offset in the rear which puts me right on the fender perfect .. so you think once i drio it the normal camber will push it close enough inside the fender well and just get a nice camber kit for the rear and once i do put some 35's on the back roll it ???????
Old Mar 22, 2010 | 11:13 AM
  #44
SN00P's Avatar
CLUB MODERATOR
i no everyone is saying 4x4 high and stuff and it looks really tall .... i think the way the camera angle made it look higher i don't no cause in the pic it looks like 4'' lift is on it but i just went outside and i can put 3 fingers in the rear fender well and my 3 fingers are tight from the top of fender to the top of my tire ... so its like 2'' high in rear
Old Mar 22, 2010 | 12:09 PM
  #45
4drmadness's Avatar
eyy keep it red if u like em man!! i have them red to!
