painted my 06 calipers today
Old Mar 22, 2010 | 12:23 PM
  #46
G2FLIP4's Avatar
everything
Originally Posted by BuckeyeInMI
Looks like you got quite a bit of paint on the rubber boots. I'd suggest taping them off next time before painting. Probably won't cause a problem, but they could lose some of their flexibility over time. May even dry out a little quicker. Just make sure you check them every 6 months to a year (as you should normally).
BTW, they look good.
Ya Ive taped them off on past vehicles and left them untaped on others... never had a problem.
Old Mar 22, 2010 | 12:35 PM
  #47
oscar_g-sedan06's Avatar
Nice work, the silver looks really good. Glad to see you painted the rotor hats too. A friend of mine has an RX-7 and he painted the rotor hats, dust shield, and calipers silver. Looks really good against his red car and black wheels. I painted everything black because I thought I already had too much silver going on with the Coupe 18's on my DG Sedan.
urs look really good too i probably would of done same thing wouldnt want to much silver...clean job did same steps
Old Mar 22, 2010 | 06:55 PM
  #48
Mustang5L5's Avatar
Originally Posted by g35snoop
i no everyone is saying 4x4 high and stuff and it looks really tall .... i think the way the camera angle made it look higher i don't no cause in the pic it looks like 4'' lift is on it but i just went outside and i can put 3 fingers in the rear fender well and my 3 fingers are tight from the top of fender to the top of my tire ... so its like 2'' high in rear
You also have the wrong tire size on there exaggerating the look
Old Mar 22, 2010 | 06:58 PM
  #49
SN00P's Avatar
CLUB MODERATOR
i understand that instead of a 35 i got a 30 .. if you got all 4 tires for what i paid for mine im sure you would jump on the deal just as fast as i did .. i really dont care its a 30 in the rear cause once i slammmmm the car it will not make a difference .. i no the ride will be different but still .. but when i do get another set of rear tires i AM GOING TO GET 265/35/19 .. but in the mean time i think a 30 will do just fine
Old Mar 22, 2010 | 07:01 PM
  #50
Heist.'s Avatar
**40+ haha. Yeah you really need to slam it to get it too look decent on 30's
Old Mar 22, 2010 | 07:03 PM
  #51
SN00P's Avatar
CLUB MODERATOR
is there really that much of a hight difference between a 35 and 40 cause my fronts are 35 and yea i can tell the fronts a bigger but its not like WOWWW big difference
Old Mar 22, 2010 | 07:08 PM
  #52
Heist.'s Avatar
Prior to getting coils I had to drop from 45 to 40 when i was on stechs i think. I got a great deal on the tires also, but I hated the height difference with a passion. It makes a giant difference. Your car is a great example it looks like you could fit a body between the tire and fender.
Old Mar 22, 2010 | 07:11 PM
  #53
SN00P's Avatar
CLUB MODERATOR
really ??? so when i put my 350z s-techs on my car i still will have a gap in the rear ... so even if i put a 35 in rear it will also have a gap or no .. what im trying to ask is when i do lower my car like 2'' what would be the best tire sizes i should run ...
Old Mar 22, 2010 | 07:15 PM
  #54
Heist.'s Avatar
The wheels your running are 19 right? i cant read what it says on the tire 235/30/19? 2 inch drop will help significantly. I had 18's so I had another inch to deal with. I don't think its going to be flush, but should look better not sure measure it out!
Old Mar 22, 2010 | 07:23 PM
  #55
SN00P's Avatar
CLUB MODERATOR
yea my rear is 265/30/19+35 in the back and the front are 245/35/19+32 .. but with a 2'' drop and fenders rolled should be perfect and a flush look .. dont you think .. the only thing i have a thought about is when i lower it someone said i wouldnt need to roll fenders in the back with a 30 there but my offset is 35 which brings my wheels right at the rear fender
Old Mar 22, 2010 | 07:24 PM
  #56
Heist.'s Avatar
yeah you should be fine
Old Mar 22, 2010 | 07:27 PM
  #57
SN00P's Avatar
CLUB MODERATOR
so i wouldnst need to roll the rears ??? i post a pic of a top view with the wheel and fender and you tell me what you think ...
this is the only thing keeping me from dropping my car cause i have everything to do it now ... i just dont want to drop the car and then see i need fenders rolled after everything is done you no ...
Old Mar 22, 2010 | 07:28 PM
  #58
cremaster's Avatar
Originally Posted by lifesgood
eyy keep it red if u like em man!! i have them red to!
don't mislead the masses. show us the new BBK!
Old Mar 22, 2010 | 07:29 PM
  #59
Heist.'s Avatar
I'm not really great with offsets etc, but i have a feeling you might.. it will be a close call. I would say yes to be on the safe side they will need a light roll at least. I'm sure someone else can come in and help
Old Mar 22, 2010 | 07:33 PM
  #60
SN00P's Avatar
CLUB MODERATOR
yes cause i hear ppl say yes to roll and hear some saying no to a roll ... my with a 35offset in the rear i would think you would have to roll them cause look at other ppl putting coupe 19s on there car with a c/z drop and they say you need to roll the fenders and stuff ... so im going to roll them this week at a local shop for $100 bucks to be safe and once i finished the roll and drop the car i think all the gaps will be gone and i will have a nice flush setup ...
